Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 03-19-2011   #11
GLMajer
Default Re: New Wheels!
I had a Quasar Blue '92 LT1 and loved it. But now have an Adminral Blue '94 and love it more!
BTW, nice wheels!
GLMajer is offline   Reply With Quote
Old 03-20-2011   #12
gbmidyear66
Originally Posted by ZR1@gmx.com View Post
Looks awesome, the car and the wheels! I would like to get my wheels refinished... Anyone know a good source in or around Missouri?
Refinishing the machined face 90 wheels seems to be a combination of art and expertise. I got my fronts finished first to be sure I was happy with the result - and I wasn't all that happy with my fronts - looked like they had water spots on the machined areas - apparently a common issue. I took the rears elsewhere and was fortunately very happy with the result.
The diamond bit used for machining and how the clear coat is applied and the casting itself all seem to be major factors in the end result.
Good luck
Glenn
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
Old 02-10-2012   #13
zr1nsxgto
zr1nsxgto's Avatar
There is a company in Huntington Indiana called Transwheel. They did a set of 90 ZR1 wheels for me and they turned out perfect. Wasn't cheap however. It's been 5 years or so back, but it was around $750 to do all 4 wheels. They look just as good as factory new. They tell me that they are the company that developed the clear coating process that is now used by GM. Still have these wheels and am just now thinking of putting some new rubber on them. My original Gatorbacks are hard as concrete.
zr1nsxgto is offline   Reply With Quote
Old 02-10-2012   #14
actually refinishing is pretty easy, did these by hand with sandpaper, and steel wool....turned out perfect
Old 02-11-2012   #15
Good luck
Glenn
Glenn,
The "water spot" appearance is clear coat splatter on dry paint....
Old 03-03-2012   #16
gbmidyear66
Lee
Are you suggesting I may be able to polish the "water spots" from the clear coat?
Glenn
[SIGPIC][/SIGPIC]
NCRS BC Chapter
Old 03-03-2012   #17
I think its possible....might try a polising compund..somthing light....call whomever did the painting and ask
Old 03-06-2012   #18
bdw18_123
actually refinishing is pretty easy, did these by hand with sandpaper, and steel wool....turned out perfect.
Interesting Lee, I might have to try that on mine. Can you give any more detail as to the process you went through to achieve that result? Did you clearcoat them afterward or just leave them bare?
My '90 rims don't have the machining on them anymore (they are just smooth with no clearcoat), the original owner must have had them polished at some point. I like the original look better though.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 03-06-2012   #19
You just need to work on them prosgressively...start with a 240 or 320 and work your way down to fine steel wool......I then rattle can cleared them...no problems the far..I was shocked they turned out so good.
Mine just had rash on the edges, although I did scuff and reclear the entire wheels....I did not remove all the clear on the centers/hubs...only were it was poor
