02-28-2011 | #1 |
Tensioner Question
While I was replacing the water pump, I noticed that the tensioner pulley is sounding a bit dry.
After exahausting the search function, I've learned that the tensioners can also loosen up over time. So is there a tensioner assembly available anywhere?? The sources that were quoted in past threads are no longer available. Worst case, new pulley/bearing I guess. Thanks for the help,
[SIZE=1][SIZE=2]Tyler[/SIZE] [SIZE=1]1993 ZR-1 - Polo Green[/SIZE] [/SIZE] |
02-28-2011 | #2 |
Re: Tensioner Question
i had this problem not long ago with the pully couldnt find one so bill b. pressed in a new bearing for me .
02-28-2011 | #3 |
When I bought my car, the seller had a tensioner for it in a box in one of the back storage bins. He knew it was going out. I just had it installed a couple weeks ago and no more squeaky belt!
The Corvette shop that did the work for me tells me the parts are available, but pricey. In other words, I was fortunate to have that part!
[B]1990 Corvette ZR-1 (#1930) Red/Black, Stock Engine, Henderson Performance custom ECM, FIC Injectors, B&B exhaust, Kenwood DNX6160[/B] Other Rides: 1992 Pontiac Firehawk (#010), 1967 Pontiac GTO 1998 Porsche 968, 2000 Harley Davidson FXST 1986 Pontiac Trans Am, 1931 Ford Model A Tudor Deluxe |
02-28-2011 | #4 |
New pulleys w/bearing are available Dayco PN 89003, and will cure the vast majority of problems. The tensioner is not available as new.
03-02-2011 | #5 | |
I will try to track one down and get it put on while the car is decommissioned. Another cold snap has hit with -37c temps, so plenty of time for a new pulley to arrive.
