I finished making my beam plates. What torque spec should I use when torqueing them down?
Dave |
![]() Join Date: Jan 2008
It depends on the size and type of bolt used????
The factory c-beam bolts
Ft lbs spec:
59 for the carrier here is the end for this spec>> ![]() 37 for the tranny end ![]() Assumes reusing OEM bolts and using OEM spec'd nuts |
Okay the beam plates are in should I do any aligning on the rear end and tranny before I start torquing them down??
Dave |
#6 | |
Damn thats clean looking underthere!!!! ![]()
![]() Join Date: Dec 2004
Yes it is!
![]() Makes me envious.....mine used to look like that....when it first came off the truck 42k miles ago. ![]()
Plead guilty to a somewhat demented mind... also it was a good start when I purchased the ZR 2+ years ago and had only 1320 miles of the odo
#10 |
![]() Join Date: Dec 2003
.....and now it makes me feel bad looking at mine
![]() ![]() Wish I had a neighbor with OCD!
