Old 02-18-2011   #21
sammy
Default Re: Codes.
or another thought maybe a piece of something got into the fuel line and is starting to plug the filter ????
Old 02-18-2011   #22
rhipsher
rhipsher's Avatar
Default Re: Codes.
I called them today to ask what they had to disconnect or unplug to remove the rear bumper and the 1/4 panel. He said they would have unpluged the antenna and the rear tail lights. He said he hopes its nothing they did but to let him know. Another thought would be the fuel pump ground wires.
Old 02-19-2011   #23
rhipsher
rhipsher's Avatar
Default Re: Codes.
I think I've found the problem. I checked battery connections and the negative battery cable was not tight. I could turn it with my finger. Tightened it up and the car fired up and idled perfect. Im a little low on engine coolant and need to do an oil change. After that I'll take it for a spin and check for codes then I'll know for sure. But no see light on start up like before. My gut tells me that was it.
Old 02-19-2011   #24
rhipsher
rhipsher's Avatar
Default Re: Codes.
Looks like I spoke a little to soon. Just fired it up again and it ran rough like before.
Old 02-19-2011   #25
sammy
Default Re: Codes.
you could be on to something with the fuel pump ground. do you have a gauge you can hook up ?
Old 02-19-2011   #26
rhipsher
rhipsher's Avatar
Default Re: Codes.
No I don't. I crawled up under there to take a look but its hard to see up in there. There's wires running everywhere behind the bumper. Id almost have to remove the gas tank to see everything. My gas tank is empty right now with reserve on and only one bar showing. So now would be the time to remove it. Plus my spare tire and assembly is removed already. Besides where do the fuel pumps ground to?
Old 02-19-2011   #27
sammy
Default Re: Codes.
i will look in my fsm when i get home this afternoon ,maybe give me a call around 6pm my time on my way home from reno right now .
Old 02-19-2011   #28
gbrtng
gbrtng's Avatar
Default Re: Codes.
If they did any welding and did not disconnect the negative battery cable, my theory about a frazzled ECM is still a good bet. Even some static electricity from sanding and painting could have zapped it.
JMHO ...
Old 02-19-2011   #29
Default Re: Codes.
Man this sucks I hate electrical BS. Are you getting any flickering in the IP while running RHIP?
Old 02-19-2011   #30
rhipsher
rhipsher's Avatar
Default Re: Codes.
I fixed it. There's always a lesson to be learned in these situations and this one was to take your time and don't take quick glances over areas your looking at. I had quickly glanced at the map hose for a split second in dim light and moved on to the rear of the car. Then I popped the hood to look everything over one more time. As I hovered over where the map sensor was I smelled gas. I grabbed a little flashlight and saw that the map hose was unplugged. End of problem. Im kinda embarrassed about that because that's the first place I looked in very dim light and thought I saw it plugged in but it wasn't. And my radio even works now. Weird.
