Old 01-30-2011   #1
kbondra
Default EZ-Clutch Pedal Extension
Bondra Performance Engineering - EZ Clutch Pedal Extension
This EZ Clutch Pedal Extension will fit all Corvettes with aluminum pedals without modifying or drilling your pedal. Installs in minutes. Made of High Impact ABS and engineered to fit your 2001-2004, Z06 and all 2006-2011 Corvettes with a manual transmission. Extends contact surface of pedal 40mm. Total Weight with Screws is 3.6oz.
Allows most drivers a more comfortable seating position so you don't have to sit so close to fully disengage your clutch. It also improves the fulcrum angle and slightly reduces the torque needed to apply the clutch. Will not alter clutch performance - designed only to improve the comfort and ergonomic position of the driver. You don't have to push your brake pedal all the way to the floor, but you do have to bottom out your clutch or risk burning it up. Vehicle ergonomics are set up to accomodate all drivers from the very tall to the very short, this compromises the seating position of most drivers.
This is the solution to that problem, it works perfectly and it looks great too!
Comes with EZ Clutch Pedal Extension, Backplate and 4 Stainless Steel Screws.
$49.00+$7.99shipping=56.99
kbondra is offline   Reply With Quote
Old 01-30-2011   #2
Default Re: EZ-Clutch Pedal Extension
Notice this forum is all about C4 ZR-1's. They were made from 1990 to 1995.
Does this application work for our cars?
Old 01-30-2011   #3
todesengel
It doesn't look like it would, bu I could be wrong. Funny that something like this isn't offered for a car designed during the disco era when people wore platform shoes.
todesengel is offline   Reply With Quote
Old 01-30-2011   #4
VetteMed
Smells spammy.
Old 01-31-2011   #5
USAFPILOT
USAFPILOT's Avatar
Are you really supposed to bottom out the clutch pedal when you shift?
I don't think I do.
Old 01-31-2011   #6
kbondra
Hi,
The EZ-Clutch Extension is made for the aluminum pedals but it will fit many other clutch pedals. You just have to drill the four holes.
Old 01-31-2011   #7
Aurora40
Aurora40's Avatar
I don't think I do.
How do you know if you've pushed it "enough" to fully disengage the clutch?
Bob Saveland
Former owner of #2517
Old 01-31-2011   #8
kbondra
Originally Posted by VetteMed View Post
Smells spammy.
No spam, just a clutch pedal extension I though you guys would like.
Old 01-31-2011   #9
todesengel
it doesn't grind when you shift lol?
Old 01-31-2011   #10
Pardon , but why would we need this
