Old 07-04-2006   #1
hihok9
Default ALDL connector?
I guess it's supposed to be beside the column to the right on the lower dash. Mine isn't there. Must be stuffed up under the lower dash panel. Anyone got a pic of what it looks like and where it should be? That way I can return mine to it's proper location once I trouble shoot my issues. Thanks!
hihok9 is offline   Reply With Quote
Old 07-05-2006   #2
Default Re: ALDL connector?
The location you describe is correct. You will most likely have to pull the knee bolster to find it. It should mount to the bolster with a screw on one side of the ALDL plug. I’m sure you will see the spot once you get the bolster down.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
