Old 12-10-2010   #71
Hammer
Hammer's Avatar
Talking Re: Fire Sale List
Yes you did....it is in that box with my Heads.....take the cam covers off and blow the doll up
Cliff, glad you finally got your stuff and you are still here adding to the forum.
Man what a pain, ey?
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 12-10-2010   #72
Default Re: Fire Sale List
Kevin is that extra Crank still available?
Old 12-10-2010   #73
VetteMed
Got my mats and fuel lines, thanks Kevin!
Old 12-10-2010   #74
Polo-1
Yes, kind of....
The extra motor parts I have was going to be a 380ci mini stroker. Then I was going to sale that. Well..... Plans change.
I tried to price the motor parts cheap for fast sell ( quick Z06 cash ). I sold the top end, thats stuff is all gone. I have all the bottom end stuff left. I can't believe no one asked for the block $1500. The liners are $1300 then you need machine work done. This block was done on the same Rottler CNC as my 402. It was $1000 for setting liners and torque plate bore and hone.
Anyways.. I have someone asking if I would finish a shortblock 380ci and sale that. It will be pan up to top deck, front cover and timing chains, balancer. A basic shortblock, just 380ci. I was hoping not to make more work for myself, but I don't want a LT5 block laying around either. If I could get someone to buy the block, you take a crank..... It would work.
Old 12-10-2010   #75
Originally Posted by Polo-1 View Post
Yes, kind of....
Pm sent
Old 01-02-2011   #76
Polo-1
HERE IS THE UPDATED LIST
Interior parts:
Seat back plastic bezel in GM bag-$25
Red driver side door panel-$50
94-95 head light/fog/abs switch assembly- $50
Motor Parts:
Power steering pump 91-95 - $75
Stock cams 91-$200 ea SOLD
Smog pump /tubes/lines 92 -$50
Misc parts:
Jack and bag-$15
Stock filter lid metal-$5
Master brake cylinder-$25
Corsa's-$500 These have been cut apart and welds removed, they can be clamped or welded again.
Rear ABS sensors-$25 ea
New found stuff
GM OEM 1990 cam cover emblems $50 They are new, just look less then perfect for in the GM bag. SOLD
Crazy Cowboy Pre-Cut Sound / Heat Insulation Kit $125 SOLD
Old 01-02-2011   #77
What type of shape is the panel in? any pics?
complete? If I understand right the cuts were just to the welds so it will fit together correctly again
Old 01-03-2011   #78
Polo-1
Door panel is in good shape. I bought it off the CF, was told like showroom...... I call it Good shape.
Corsa Yes, slip fit again. just had to knock off the welds. (grind) I can get pictures if you like. Pictures are back a few pages when welded.
Old 01-03-2011   #79
Door panel looks good, any cracking on the ribs on the back side?
Old 01-03-2011   #80
Polo-1
Cams are perfect like the lifters they rode on in the heads you bought. They are from the same 91 motor.
