Old 08-19-2010   #1
Don in VT
Default 90 ZR1 alternator --Supplier
Hi All,
Is there a supplier (new or rebuilt) for the alternator and or starter ?
Ebay shows nothing for the alternator.
Our new ZR1 is running well and most of the small projects are done.
Yet to go are, oil pan gasket, BU light switch and the clutch M and S.
Cheers to you all
Cherry and Don
Don in VT is offline   Reply With Quote
Old 08-19-2010   #2
pantera1683
Default Re: 90 ZR1 alternator --Supplier
You can get either rebuilt locally pretty easily, just go to an automotive electrician.
Old 08-19-2010   #3
Concur a lot of local rebuilders can handle this for you
Old 08-19-2010   #4
DO NOT get the e-bay alternator !
As above.....good advise.
Old 08-19-2010   #5
Don in VT
Great idea on the local rebuilders. I guess I will have to get a starter and alternator rebuildable core and go from there.
Old 08-19-2010   #6
Just yank yours out and have the rebuilder do his thing. It won't take him long.
Old 08-19-2010   #7
jrd1990zr1
jrd1990zr1's Avatar
Typically it is the front bearing that goes.If you have access to a press, pick up a new set of bearings. When we rebuilt my alternator the bearings were < $20.00.
Old 08-19-2010   #8
And you dont have to worry about getting the wrong alternator in the wrong Clock position.
Old 08-19-2010   #9
91vettezr1
91vettezr1's Avatar
i know ac/delco sells a rebuilt alternator not new. rock auto.com or there are a few ac delco vendors on ebay that sell them. usually around $179
91vettezr1 is offline   Reply With Quote
