Old 07-23-2010   #11
Default Re: help on keys
Originally Posted by John Boothby View Post
I had my dealer check the resistance of my key (no charge) and I wrote it down for future reference. I also ordered a blank key with correct resistance from MidAmerica http://www.mamotorworks.com/corvette?frame=1.1033 . I believe it is about $25. I would suggest this to all who have not done this yet. I was a boy scout many moons ago and still remember the motto: "Be Prepared".
Great information John I added that information to post #11 above which has discussion/information summary. It appears if you have your own original key, you can for maybe a total under $30 buy a correct blank from MidAmerica and go to WalMart and get that blank key cut as a spare key.
You can measure the resistance of you own key
Take an ohm meter and measure across the little gold chip inside the black area in center of key.....measure from one side to the other
Old 07-23-2010   #12
xlr8nflorida
xlr8nflorida's Avatar
Damn Dynomite, If you had code #8 I could get you an ignition key for under $10.00.
I might be able to get code #7, I'm checking into it for you.
Old 07-23-2010   #13
xlr8nflorida
#8s are cheaper or you happen to have the same #
I'm not sure what #'s I have. I have multiple sets on my Corvettes except for my 93, I only have 1 set and that rarely gets driven. I'm going check all mine this week.
I do have an extra ignition key for #14 but I highly doubt any of my cars are #14. Also, its not 100% perfect, it has GM logo on one side and cadillac on the other although I'm sure it would work fine regardless.
If anybody wants to post up their Numbers I could probably get a cheaper rate if we buy multiple keys etc.
Old 07-23-2010   #14
Hammer
Hammer's Avatar
Talking Re: help on keys
Check at a GM dealer. I think most any of them can make a key for around $25 or so. I got a blank off ebay for $12 and then took it to Wally World. They cut the new one and it worked fine.
Old 07-24-2010   #15
rhipsher
rhipsher's Avatar
I want to hear more about the brothel.
Old 07-24-2010   #16
sammy
no its not there had 2 different sets of keys that were connected by one of those plastic clips. after playing with 2 girls for a couple of hrs ,i was in lala land when i went to the car to drive home. i didnt even notice the other set was gone till about 4 days later . they have looked allover and under at the brothel .ao i guess monday when i go to reno i will stop by the dealer there . and yes those 2 ladies were very fine indeedee
Old 07-24-2010   #17
gbrtng
gbrtng's Avatar
So a hooker has a set of keys for your car? Bye, bye car. Change some locks instead.
Old 09-22-2010   #18
sammy
well heres the paul harvey on my key journey. i got the key ccodes from a dealer and the keys work in both locks but on the ignition lock the key turns it but it doesnt start . i also noticed that the security light stays on when trying to start the car . i am wondering if the pellit code i remembered was the wrong one . can the dealer also tell me the pellit code . i have just 3 days to figure this out before i have to leave and go back to work . anyone know the answer on how to find the pelit code when i dont have an old key to work with .thnx for your help
Old 09-22-2010   #19
16 codes,16 keys would be my guess.
Old 09-22-2010   #20
sammy
so that means i have to spend 300 in keys to find the right pelit , sure hope there is another way. but if i must i will
