06-07-2010 | #11 | |
Re: Oil Dipstick
Just so I understand better as I've never had a problem with my dipstick (other then its weird readings it gives from time to time) I thought what I posted is that entire rubber piece- top and bottom. Are you saying there are 2 rubber pieces or seals there instead of 1? |
06-07-2010 | #12 |
Re: Oil Dipstick
[QUOTE=Dynomite;91545]What you show in your picture is the seal for the dip stick tube which fits into the engine block at the bottom of the dip stick. What I am looking at is a rubber or soft plastic (not removable) seal at the top of the dip stick inside that dip stick housing that fits over the dip stick tube as you insert the dip stick.
Makes perfect sense now- thanks In my mind I had that all has one unit. I knew you would come through with the photos - you always do. Hey can you post a photo of Dex-Cool for me? |
06-07-2010 | #13 |
Re: Oil Dipstick
pm sent
Bigun 1990 ZR-1 #618 Black/Gray (sold) NCRS, ZR-1 & NCM member |
06-08-2010 | #14 |
Re: Oil Dipstick
So in cars other than ZR-1's, has anyone had this problem. If so, what do you do for a fix and what do you replace it with?
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
06-08-2010 | #15 |
Re: Oil Dipstick
Well, my 94 behaves similar in that after driving for a while, dip stick will pull up by about 1/4". I think my 91, even when the car was brand new, did the same thing.
I did not pay much attention to this figuring it was pressure build up in the crankcase. I remember reading that design engineers had some issue with high pressure LT5 was generating in the crankcase and resorted to some "creative" solutions. Am I to understand most other LT5s do not push the dipstick out a little after spirited driving? |
06-09-2010 | #16 |
Re: Oil Dipstick
with the high rpms and all the nice tightly packed whirring parts in the LT5 they have a bit more "windage" and blowing out the dipstick at high rpms isn't at all uncommon
my LSV does it at the drag strip. leak down test will assess the overall health of the engine, and yes, as the engines get a bit long in the tooth a bit of blowby and cankcase pressure is common put a little spring on it or the seal. I'm going to do this too, but the only time that happens to me is over 7300 (*so everytime I drive her*)
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
06-11-2010 | #17 |
Re: Oil Dipstick
I understand!!
[SIGPIC][/SIGPIC]George C 91 Black/Black ZR1, #2 of 8 black widow cars 15 black/red Z06 :hello: |
06-27-2010 | #18 |
Re: Oil Dipstick
This happens with mine as well. I noticed it earlier this month. did the seal fix it?
-Shaun 1991 Charcoal Metallic ZR1 #730 [URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL] [URL="http://community.webshots.com/user/shaun91zr1"][/URL] [IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG] |
06-28-2010 | #19 |
Re: Oil Dipstick
06-28-2010 | #20 |
Re: Oil Dipstick
Thanks Luis, if you figure it out let me know, and if I figure it out I will let you know.
