05-28-2010 | #1 |
Slight Hesitation
When I accelerate, mostly at low speeds. I don't feel it at higher speeds, but I guess it could be there. New FIC injectors, new GM (from White Racing Prod) PCV connector, car runs and idles well except for the hestitation
Thanks for the help JIm |
05-28-2010 | #2 |
Re: Slight Hesitation
Okay, we are not talking about 2* port throttle "tip in" right? This is just the run of the mill hesitation when applying moderate pedal pressure?
The FSM lists: Fuel pressure/ contaminated fuel. ( fuel filter okay?) plugs & wires. ( and I guess coils too? ) TPS for binding or sticking. Alternator output okay. less that 9v or more than 16v is a problem. Ignition module ground, CKT 453. Purge canister operation, chart C-3. primary injector balance test Tom
