Old 05-25-2010   #1
pantera1683
Default Shelby Series 1 Wheels fitment
Okay I've tried reading all the posts on these wheels and am not sure what I need to do, if anything to make them fit.
I have a 94 with Wilwood 6 piston calipers and 13" rotors (part no 140-8337) up front and just purchased some Shelby wheels. I don't have the wheels yet and want to know what I have to do to make them fit. I would like to do as little as possible.
Old 05-25-2010   #2
FULLPWR
FULLPWR's Avatar
Default Re: Shelby Series 1 Wheels fitment
pm USAFPILOT he could help you out for sure..
Luis
FULLPWR is offline   Reply With Quote
Old 05-25-2010   #3
USAFPILOT
USAFPILOT's Avatar
From what I have read if you use the stock brakes the Shelby Rims fit with no issues...but for larger calipers you have to unbolt the centers from the front wheels and move them towards the outside of the wheel...then run a wheel spacer to get brake caliper clearance.
Old 05-25-2010   #4
pantera1683
So the rear wheels will fit fine as is?
Old 05-25-2010   #5
USAFPILOT
USAFPILOT's Avatar
I'm not sure about the rears...i didn't pay it to much concern because I run the stock brake system. The Shelby Series 1 ran the same brake system, so I guess it is good enough. Hah...I'd love a Wilwood setup.
If you have stock rear brakes; yes they fit, at least that is what I was told. My tires come in Thursday, and as soon as I get them mounted and find a Lugnut Key for those crazy lugnuts; I will mount em up.
Old 05-25-2010   #6
pantera1683
If you can't find your lugnut key, you might be better off taking it to discount tire, they will take them off for $20. Of course the locks will be useless after but they are pretty useless now anyway.
Old 05-25-2010   #7
Locobob
I reversed the centers and mounted them with 1/4in spacers and longer wheels studs - all four. Keeps the tires inside the fenders and allows enough clearance for the 4 piston Alcons I have up front. You can leave the rears alone if you want but they will stick out a half inch or so.
Robert
Old 05-25-2010   #8
I did the same:
with the centers on the inside for the rear they stick out a bit:
-=Jeff=- is online now   Reply With Quote
Old 05-25-2010   #9
I did the same:
No more than my Fikse Fm-5s. They look great
Old 05-25-2010   #10
pantera1683
I don't mind them sticking out by 1/2". They look pretty good like that. My main concern is the fronts clearing the Wilwoods.
