#21 |
#22 |
sorry fo the typos i didnt have my glasses . it should read he is right . inyo county,one only has to smog their car when buying or selling. sure you can have the back yard its 29 acres
#23 |
if one wants to use the lt1 tips , just step up to a 3 in super turbo muffler. then you dont have a cork in the system . the key is the super turbo. the ultra flows will drone. we tried them and sent them back on the dyno max 30 day return if you dont like them . my exhaust is as quiet as the stk exhaust with headers and just the right amount of sound when you floor it . as i shared before there is a vidoe on utube of the car ayt fontana on 2-28.its the one jetta vs corvetteat acd
#24 | |
![]() Join Date: Oct 2004
The C4 exhaust as it's suspended/hung from the chassis with metal hangers and only coiled springs is going to be very susceptible to resonance in the cabin. A potential fix for this although unsightly could likely be ballast. An exhaust tip extending beyond the fascia by a good bit is also a plus. How much restriction would you expect is created by the 2 1/4 outlet? Bettcha there's no "SOP" feel! Is there a definitive difference on dyno test vs. anything else? Probably on nothing other than larger cubed or modified cars. Maybe even then, NOT! It's certainly a "cost effective" option that retains "the look"! I believe that was/is the OP's goal!! |
#25 |
you could put in a a 21/2 in xpipe and the do the 3 in super turbo mufflers and transfer the tips off your old exhaust as i did .i want the 4 outlets like the 90 on my 92 , x pipe cost 175 mufflers 115 inc shipping and 150 maybe in muffler shop labor cost .paint the mufflers and tips black and it will look stk to most .if one really wanted to fool people you could cut the case off your stk resonator and cover the xpipe with it .
