03-29-2010 | #11 | |
Re: Extra mouse power
6 of the 13 were finger tight only. Cleaned it up installed a new gasket from Jerry and torqued it down with red locktite. Biggest leak found was the oil filter adapter on the front of the engine. The 2 lowest of the 3 bolts were only finger tight. Replaced that gasket and torqued with red locktite. |
03-29-2010 | #12 |
if i can ask how much of a pain was it to change the gasket on the oil filter adapter ? i havent done that yet but think i may have to
03-29-2010 | #13 | |
The one lower bolt is a tight squeeze over the lower radiator hose. Wasn't too difficult. I've probabily spent 3 times more time and effort cleaning up the nest and the past oil leak residual than taking things apart and putting back together. |
03-30-2010 | #14 |
thank you so much for the info
