Old 03-28-2010   #11
Default Re: TB coolant crossover,any disadvantages?
Originally Posted by scholtmj View Post
Thats it,I was all set to make one of these but couldnt see any room under the plenum.Now I know it can work Ill go take another look,Thanks for the link.
Old 03-28-2010   #12
jonszr1
jonszr1's Avatar
after i did this mod .i took 2 3 ft sections of hose and ran 1 to the front air dam and the other tothe right side wheel well so that cool air can circulate thru the throttle body, dont really know if it helped ,but figured it couldnt hurt
Old 03-28-2010   #13
carter200
carter200's Avatar
Coolest thing you could do for your throttle body is to install one of the Billet trottle body plates
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 03-28-2010   #14
Scrrem
Scrrem's Avatar
Yep, I love mine...thanks Carter!!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-28-2010   #15
carter200
carter200's Avatar
Rich,
Glad I could help
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 03-30-2010   #16
Yep! I didn't have the bypass though. The stock hose ruptured, facing towards the plenum (of course) & flooded the valley. Stuck in a gas station, fixed it, starter toast but easily push started (small miracle).
Lesson: don't forget the "little" coolant hoses when you replace the "big" ones.
May I ask what type of hose you guys use as replacement hose for the coolant lines along the plenum? I know I can get 3/16" fuel hose, but I'm not sure that is okay for this situation.
TIA
Old 03-30-2010   #17
Aurora40
Aurora40's Avatar
You should be able to buy heater hose that is that size. I suspect fuel hose would work too, though?
Bob Saveland
Former owner of #2517
Old 03-30-2010   #18
Thanks Bob.....sometimes it's the simple things that escape my eye!
Old 03-30-2010   #19
bobbyhi
bobbyhi's Avatar
I used fuel hose on mine................
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 04-10-2010   #20
Got the job done,what a pain in the a$$.Despite the fact that this pipe was supposed to go in with out removing the plenum,that wasnt the case.There was no way in hell this was going in without at least raising the front of the plenum.Then I had to take my tube bender and change the pipe quite a bit on the driver side.Once I got the plenum up I could see oil residue everywhere so I went ahead and removed the plenum to clean everything up.While I had everything apart I found the secondary solenoid wasnt holding vacuum.In the past the pump would evacuate the system and cycle one second every 7 seconds then it got down to about 4 seconds.Replaced the solenoid no it holds vacuum for maybe 30 seconds or longer.The cars got a stumble if you stab the pedal off idle.Found a vacuum leak at the PCV fittings so Im working on that now.I ran a preformed hose off of the TB nipple to give it a finished look.[IMG][/IMG][IMG][/IMG]
