Old 03-19-2010   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: New LT5 Crate Engine $7500
Jerry,
I noticed the same things as you've mention.
One thing is the oil filter, looks to me to still be the original.
And no clear indications the throttle cable clamps have ever been installed on the plenum.
But then again you look closely at the paint on throttle body and it clearly appears to be lifting at the cover plate edge.
Regardless of the good price I think in this case prudence dictates a thorough firsthand inspection to clear up any uncertainties prior to any purchase decisions.
Old 03-19-2010   #12
Jagdpanzer
Jagdpanzer's Avatar
The first photo clearly shows the bell housing installed.
For the sake of comparison here are a couple photos a Peoria, IL Chevy dealer sent me of a 95 motor they were selling a couple of years ago
Notice the plastic bag Jerry mentioned
Old 03-20-2010   #13
Jerry,
I agree with you Phil, needs first hand confirmation. The exhaust plugs & intake cover stuff could have been put on the takeout engine (if that's the case) . Even the crate wood looks like it's weathered.
Old 03-20-2010   #14
Polo-1
thats the worst NEW CRATE engine I have seen. Was it stored outside in the weather
Old 03-20-2010   #15
xxxscimitarxxx
if it is what it says then l would be interested ..... but as you say....for a supposedly unused crate engine it sure looks a bit weathered.....has anyone seen this close up yet
xxxscimitarxxx is offline   Reply With Quote
Old 03-23-2010   #16
SnakeSkinner
Is it just me or does it look like one of the intake runners (front drivers side) is caved in?
SnakeSkinner is offline   Reply With Quote
Old 03-24-2010   #17
Looks like it to me
Old 03-24-2010   #18
Polo-1
someone is going to get BURNED on this deal
Old 03-24-2010   #19
Jagdpanzer
Jagdpanzer's Avatar
Are you refering to the to the upper right runner in the left pic below?
If so this is a cast in feature of the later 93-95 style plenums to allow clearance for the throttle cable in the area where it connects to the TB.
The right pic is of the ealier 90-92 style plenum.
Old 03-25-2010   #20
Polo-1
I just got the high res pictures of it..
It's not the new crate motor, it's the take out. Mostly likely a Chevy dealer went out of business and this was sitting around. The pictures clearly show oil/dirt in the wire loom, fuel rails, under water pipe.......
