Old 03-19-2010   #1
Default Power Antenna Mount Questions>>
I found the Power antenna bracket dangling under the car yesterday..
What Size nuts are used where the mount bracket attaches at the bumper/fender seem
Also what size are the bolts on that go into the bottom of the antenna to hold it to the bracket?
Old 03-19-2010   #2
Toyvet1
Default Re: Power Antenna Mount Questions>>
Ill be home all day if you want to stop by and look....
Old 03-20-2010   #3
I might.. we will see how the day goes. I can SEE them and all, just was hoping to know the exact sizes
Old 03-20-2010   #4
Are these the 8mm heads with the large washer?
about 13mm long
Old 03-20-2010   #5
about 13mm long
you tell me.. I NEED them as I don't HAVE THEM
Old 03-20-2010   #6
The ones I took off the car, and are sitting on the ramp are 8mm head, 13mm, long and calipers show about 5mm width, 20mm washer.
Old 03-20-2010   #7
those thread in the bottom of the power antenna unit? that sounds right..
was there a ground strap on one of those too?
Old 03-20-2010   #8
gbrtng
gbrtng's Avatar
There's a ground strap at the top and bottom. The top one makes removal a b*tch unless you just rip it off because you have to remove the leftmost taillight to get to it.
Old 03-20-2010   #9
On the bottom one, is it sandwiched between the bracket and antenna body? or another bolt?
Old 03-20-2010   #10
gbrtng
gbrtng's Avatar
The bottom strap is bolted to the bracket fastener - but not sandwiched.
The FSM page 9A-21 shows the strap fastened with one of the bottom bracket bolts.
