Old 02-25-2006   #21
BBBAD94ZR1
BBBAD94ZR1's Avatar
Default Re: Drivabilty issue.
Plugs I put in were 413's not 419's regapped and same issue.
RAy
BBBAD94ZR1 is offline   Reply With Quote
Old 02-25-2006   #22
Demps
Demps's Avatar
I hate to be the one to say it but get the Helms manuals.
Does the car act the same when it is cold (first started) and when it is hot (over 120 deg F H20 temp)? (o2 sensor)
Go buy a fuel pressure gauge with a drain hose on it. Connect to the schrader valve on the fuel rail on the passenger side front. (filter)
The manual references fuel or spark--which everyone else has. Could be the spark plug wires are broken down or damaged. Measure the resistance across the plug wires (boot to boot):
8/5
1/6
4/7
3/2
Old 02-25-2006   #23
BBBAD94ZR1
BBBAD94ZR1's Avatar
Thanks,
I have the books, I will do this next week and let you know my findings.
RAY
Old 03-01-2006   #24
BBBAD94ZR1
BBBAD94ZR1's Avatar
Thumbs up Re: Drivabilty issue.
I got the Z happy again , I took it to the dealer the Rick recommended flushed the injectors 3 times, changed the fuel filter, and new plugs again. Two of the plugs fouled out from the injector cleaner. The car needs new exhaust the resonators are making noise when downshifting. Think im going for the B and B. What do you think?
The car now runs and idles perfecto! I did the nickel test and it works. I want to thank all of you for support. I also got pulled over twice on the way home from the dealer.
The cops pulled me over for no inspection sticker and after I explained the situation they were cool and commented on the car.
You are a great bunch of people.
Thanks again....
RAY
Old 03-01-2006   #25
Glad it was that simple Ray!!
Old 03-02-2006   #26
now u is da man mr ray in the baaaaaaaaaaaaaad 94 zr-1.........................
Old 03-02-2006   #27
blackjack
pedal to the metal
blackjack
blackjack is offline   Reply With Quote
Old 03-02-2006   #28
john k
Happy your car is runng well glad we could help.
if you need anything else dont hesitate to call.
john
john k is offline   Reply With Quote
Old 03-03-2006   #29
Ray, mind if I ask a Q? What exactly was this "cleaner" & how was it applied??
thanks for any light!
Old 03-03-2006   #30
BBBAD94ZR1
BBBAD94ZR1's Avatar
Talking Re: Drivabilty issue.
Tom,
The cleaner was applied directly to the injectors and the fuel supply was cut off. The car only ran on the injector cleaner. This process was done three times. I seems to have worked pretty well and saved me 2 grand on injectors and install. The gm part number is 58cpcr3 and a can of Bng injector cleaner in the fuel tank to clean out any carbon deposits.
Thene finally a set of new plugs part number 5614355 /41-913 plugs gapped .50. The car runs so smooth the nickel test actually works.
I will try to post a video of this.
RAY=D>
