Old 02-12-2010   #11
shaynezrl
shaynezrl's Avatar
Default Re: rookie question
I not only removed the cam covers but the heads the same way without removing the brake booster. After I had the heads and oil pan removed I did not have much left that I could not lift out by hand
Good to hear you got all the bolts out without messing up any torx
Wow..that's cool. I have read before that you have to remove the engine, anytime you need to service the heads. That is too advance for me though. I would have to get a Hayne manual first. I was really carefull with the torx. I only have six that was up front the rest was hex bolts.
shaynezrl is offline   Reply With Quote
