Old 02-10-2010   #91
Default Re: Can I get a lift?
Originally Posted by flyin ryan View Post
Strange for your guys' area & this time of year, isn't it?
Yeah it is.. we rarely get Earthquakes out here
Old 04-03-2010   #92
Ok, pulling the trans this weekend, if you don't have a lift...you need one. This is a joke now vs working on your back. Also have a trans jack I got from Greg Smith, only 144.00 delivered and 1000lb capacity.
Old 04-04-2010   #93
Amen Brother!
I'm sure you will enjoy that equipment for a long time to come!
Old 04-04-2010   #94
phrogs
phrogs's Avatar
Do you know the part number for your tranny jack the only ones I saw were in the $300 range.
JOHNNY P
Currently own
Old 04-04-2010   #95
http://www.gregsmithequipment.com/1-...k-p/ht0304.htm
Old 04-04-2010   #96
The only down side is, even if the jack is at its lowest point, with the trans and shifter on the jack, there would be no way to get it out from under the car.....that is without lifting it off the jack and to the floor.
Should clarify: with my garage clearance.
Old 04-05-2010   #97
phrogs
phrogs's Avatar
I just measured I have the clearance with my garage.
JOHNNY P
Currently own
Old 09-29-2010   #98
Hmmmmm......got a leak dripping on the windsheild from the ram.
Old 09-30-2010   #99
undercover
Hmm... that's because you went with a Direct Lift.
...just kidding - even the Bend Pak's are made in China now. Do you always release the hydraulic pressure and let the weight rest on the mechanical stop? If you leave it hanging by the cables, you could get a little bleed-off.
(been lurking, finally registered even though I'm sans ZR-1)
undercover is offline   Reply With Quote
Old 09-30-2010   #100
sammy
Yes it will be tight but will work. Need to get the cars stacked.
are stacked zr1s a double d cup
