Old 01-25-2010   #1
Toyvet1
Default 1990 Injectors
I just got back from FIC a full set (16) of rebuilt Bosch injectors. Fic flow checked and will provide a 3 year warranty to the new owner. $300 shipped.
Old 01-26-2010   #2
jrd1990zr1
jrd1990zr1's Avatar
Default Re: 1990 Injectors
Are they compliant with the 10% ethanol currently in gas? Ready to install? If so I may be interested.
Old 01-26-2010   #3
jonszr1
jonszr1's Avatar
yes they are . i have a set installed in both my zr1s.in fact i pulled out the rcs that were in the 90 and put these in . the car had more balanced blk learns with the fic injectors .with the rcs the blk learns were off 3 t0 4 points. installed the fics and the blk learns were either the same or only 1 pt off . jon is a great guy to deal with and great customer service.
Old 01-26-2010   #4
jrd1990zr1
jrd1990zr1's Avatar
You sound like you know a lot about the injectors. Toyvet1 is selling a set of rebuilt Bosch injectors. Have you seen any difference between rebuilt verses NOS Bosch injectors? I don't want to go to the trouble of pulling my plenum to replace the injectors and since they are rebuilts is there a potential for an early failure? I have not yet ohmed out my injectors in the car, I recall you can do this from the back of the ECM. Are you aware of a description on how to do it?
I'd like to buy these from Toyvet, I am a realitive newbe when it comes to pulling the plenum, I am just trying to be careful.
Thanks for your thoughts.
Old 01-26-2010   #5
jonszr1
jonszr1's Avatar
i have one rebuilt set in my 90 that i drag and an nos bosch set that is in the 92. they both work well .if you are worried at all, i would ask if he has had them in the car and if so how long they have been out . sometimes they can get sticky if they have been out of the car for a long time . you can allways call jon at fic injectors and ask if you have a problem with them will he warrenty them even though you are buying them from a second party . that way you would be confedent of using them . hope this helps . before you pull the plenum make sure you get a set of plenum gaskets . i would get those from jerrys gaskets he is a member here and his gaskets are first rate .
Old 01-26-2010   #6
Toyvet1
I put the Bosch in about a year and a half ago. I replaced the multitech that were 18 years old.
This winter i replaced the coils and while I had the pleunem off I decided to put in the new Multitech replacements FIC sells. I talked to Jon and sent the Bosch in to be checked. I was told to tell the new owners to call him and regesiter them for a 3 yr warranty.
If you have any questions about it give Jon at FIC a call. FIC is a great place to deal with,,
Old 01-27-2010   #7
jrd1990zr1
jrd1990zr1's Avatar
PM coming your way!
Old 01-27-2010   #8
jrd1990zr1
jrd1990zr1's Avatar
Thanks for the advice. Going to put in an order with Jerry. I understand I may also need the secondary seals too?
Thanks again, John
Old 01-30-2010   #9
Toyvet1
Sold, thanks Guys
