Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 12-14-2009   #21
QB93Z
QB93Z's Avatar
Default Re: Maintenance day in MD - 12 December 2009
Here is an inside pic of Rich's nice looking Bright Red 1990 ZR-1 after the oil change:
Old 12-14-2009   #22
Scrrem
Scrrem's Avatar
Damn that car looks right at home on that lift
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-15-2009   #23
z proud
z proud's Avatar
We didn't get to the INFL REST job. We got side tracked trying to figure why the Theft Deterrent alarm goes off on my 1994 ZR-1 when I open the door with the key from the driver's side.
Jim, their is a switch on the back side of the lock cyl that is more than likely broken.
If you can not reach the door handle bolts drop the door latch to acess the bolts
z proud is offline   Reply With Quote
Old 12-15-2009   #24
QB93Z
QB93Z's Avatar
Thanks, that is good info. I guess the switch tells the Theft Deterrent System that the locks are open because the key was used. Is that the way it works?
Old 12-16-2009   #25
LORDVDR
Jim,
Let me know when you decide to tackle the INFL REST issue. Mine is doing the same thing.
Steve
LORDVDR
Steve Miller
[URL="http://www.Alive-N-Kickin.net"]www.Alive-N-Kickin.net[/URL][SIGPIC][/SIGPIC]
LORDVDR is offline   Reply With Quote
Old 12-16-2009   #26
QB93Z
QB93Z's Avatar
Can do!
Maybe we should assemble two crack maintenance teams and see who can fix the problem first. A side-by-side maintenance race for a case of beer.
What do you think?
Old 12-17-2009   #27
Just a fwiw on the INFLREST code clearing. The hardest part of the job for me was clearing the code once the grounding issues at the sensors were resolved. I don't have a Tech1A, and my snap-on scanner will not clear that code because I don't have that cartridge with the SIR software.
I made a momentary switch from a door bell and used phone wire so I could plug the leads into the ALDL. I was having trouble with the FSM's listed time duration when you ground and then unground the ALDL pins. There seems to me to have been very little wiggle room and I never got it correct. That's why I made the door bell switch and used a watch to count off the seconds. Got it the first time which was sweet considering I tried like 20 times using the "one- one- thousand, two- one thousand" method with no joy.
Old 12-19-2009   #28
z proud
z proud's Avatar
[quote=QB93Z;77030]Thanks, that is good info. I guess the switch tells the Theft Deterrent System that the locks are open because the key was used. Is that the way it works?
Jim[/quote
Correct
