Old 12-13-2009   #21
Default Re: Help! Engine Noise
Where would we be without all the good folks & the forum to put us in touch?
Old 12-13-2009   #22
QB93Z
QB93Z's Avatar
Rich,
Let me know when you are going to do the job. I will try to come down and lend a hand.
If the pump doesn't come with a gasket, get it from Jerry!
Old 12-13-2009   #23
Scrrem
Scrrem's Avatar
Originally Posted by QB93Z View Post
Rich,
Thanks Jim! When I get everything together, I will put it out as a WAZOO event and anyone who wants to help or supervise will be welcome.
Thanks to everyone who had input on this thread, appreciate all your input, this is what makes this site the best
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-13-2009   #24
Hammer
Hammer's Avatar
Talking Re: Help! Engine Noise
Absolutely Jerry. The Registry in action.
Old 12-13-2009   #25
While you had the belt off you did reach down and gave the WP pulley a spin right?It would be a kick in a balls to do all this work only to find out it was something else.
Old 12-14-2009   #26
Scrrem
Scrrem's Avatar
No, but I can do that this week. If it's making a noise like that I guess I should feel some kind of resistance or a bad spot on the bearing as I turn the pulley?
Rich
Ron Davis Radiator
Old 12-14-2009   #27
QB93Z
QB93Z's Avatar
Rich, Since the noise went away with the serp belt off, the faulty component still could be any of the things that the belt touches:
Water pump
Alternator
AC Compressor
Power Steering
Idler Pulley
Crank pulley/torsional damper
You may want to keep checking to figure out which one it is before you replace the water pump.
Old 12-14-2009   #28
Rich
Rich Im thinking Jeff feels you should still hear some of the noise when you give her a hand crank. It may be lower in volume and a different pitch but you should still hear it. If its a spun bearing you might even feel resistance. Which is futile. But as posted above Jim is right with the S belt off everthing is in play. Did you see any rise in temp with this new noise or did you not notice?
Old 12-14-2009   #29
Scrrem
Scrrem's Avatar
No, the temp was still in the normal range. I'm just puzzled what could be making a knocking noise in a water pump. Usually they squeal or start leaking, neither if which I have. Is the bearing in this water pump a true bearing or is it a bushing? I will pop the belt off again this week and give it a good rotation analysis, see if there are any flat spots or resitance felt.
Rich
Ron Davis Radiator
Old 12-14-2009   #30
Rich
Rich I have never taken an LT5 water pump apart but I believe its a compressed Sleeve bearing. Somebody here may know for sure.
