Old 11-25-2009   #11
limey
Default Re: Group Buy on AC Compressor R12 OEM Denso 471-0336 with Clutch??
[quote=xlr8nflorida;75454]
Originally Posted by limey View Post
Ahh, indeed things are not always as they seem.
I will double check the clutch but its a specific Denso Compressor for LT-5, and seems stupid that Denso would sell a specific Compressor for LT-5 and bolt the wrong clutch on it.
What are the part numbers of the correct clutch for the LT5?
1990 ZR-1 uses clutch assembly part 10158044 NLA
The 90-91 are the same compressors, BUT not the same clutches, the 91-95 uses clutch part # 10243785, also, the 91-96 LT1 - LT4 cars clutch isn't the same as the LT5, they use part # 10243784
The only differences with the 90-95 clutch assemblies are the wire connectors, the 90 is unique, the 91-95 are the same for all years.
Gets confusing i know, but you should try and inventory this ****.
limey is offline   Reply With Quote
Old 04-18-2010   #12
VetteMed
Bump for an old thread -- AM I understanding correctly, that a 1990 compressor can be used in a 1991, if the wiring harness connector is changed? Or is there some other difference that makes this impossible?
