11-22-2009 | #1 |
Sometimes don't start
Hi Guys,
How are you??? I have a little big problem with my Z. It's happen 2 times that the starter don't run. When the car is hot, sometimes the starter don't run. You can turn the key on, push the clutch pedal, the security light off but all dead. I by-pass the imobilizer(vats) with the resistance and the car run great, but now i have this problem. What can be???What i can test? Thank you so much for help!!!! |
11-22-2009 | #2 |
Re: Sometimes don't start
This dreadful condition is commonly known as the................
"DREADED NO START." http://www.zr1netregistry.com/forum/...80&postcount=2 Before you hack in to your wiring harness to perform my patented DNS Mod, there's quite a list of things to check first. Have you recently washed the engine of your car? If so, you're probably going to have to replace the starter. http://www.zr1netregistry.com/forum/...read.php?t=593 -Battery -Battery cables -Battery connections -Measure starter voltage -Check VATS http://www.zr1netregistry.com/forum/...42&postcount=4 -Jumper out the Clutch Safety Switch http://www.zr1netregistry.com/forum/...0&postcount=16 -Replace the Starter Relay -Remove the Starter and have it tested -Resist the temptation to throw heavy objects and stay away from any flammable liquids and matches. TomC "Crabs"
11-22-2009 | #3 | |
Thanks in advance |
11-22-2009 | #4 | |
Starter voltage can be measured at the clutch safety switch. If voltage is less than 9.5v, starter won't engage. TomC "Crabs"
11-23-2009 | #5 |
dont mean to hijack this thread . but i am having a starter prob. when i turn the key it clicks it does this 2-3 times then the starter engages . does that mean i have a selinoid going out . and does anyone know where i can get a selinoid if thats it .thanx
11-23-2009 | #6 | |
Thanks Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
11-23-2009 | #7 |
i just replaced the battery,as i thought that was it .but darn its still doing the same thing .
11-23-2009 | #8 |
Thank you so much guys...for me the 90% is the starter..it's a problem legacy to the temperature.
When hot sometimes don't start but if i turn the key there is an absorption. When the temperature go down it's start as never happen. As i write the battery is new (1 years old) the vats is bypass, i think that if was a clutch switch problem it never start...or not?? |
11-23-2009 | #9 |
best way to ck for the clutch switch is to watch the volt gauge while trying to start the car. release and press in om the clutch id the gauge goes down when you press it in the switch is ok
11-23-2009 | #10 |
Sorry jonszr1...i don't understand what you write.
May you explain better??Sorry, with simple words |
