11-05-2009 | #11 |
Re: My clutch issue
I cleaned the bolts and they felt good, no off axis movement, endplay or binding. The length might be the thing though I will check that out.
Dave |
11-06-2009 | #12 |
Re: My clutch issue
When I was cleaning the c-beam I noticed that the center cross trusses braces were bent. I looked at my 1984 c-beam and it didnt have the bends. Is this normal or is it distorded?
Dave |
11-06-2009 | #13 |
Re: My clutch issue
Holy **** Dave. I'd have to say that happened in the accident. I know it wasn't like that when they changed the clutch. Possibly the reason the other damage occured also although I know you had mentioned noise before, but dude, you drove that car over 10,000 miles. Think about it. Can you go back on your insurance company for repairs??
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
11-06-2009 | #14 |
Re: My clutch issue
Ya I could see how the wrinkle in the c-beam was caused by the rear end collision enven thought there was no chasis damage. But for the life of me I cant see how the accident caused the bolts to come loose and damage the throw out bearing. Also the strange noise stayed the same before and after the accident. I will say one thing though you old car is cleaning up nice. I hired a guy to help me with the clean up, I pull a part off and he cleans it so far its working great. I'll give you a call later though.
Dave BTY John you have a nice avitar pic |
11-06-2009 | #15 |
Re: My clutch issue
I believe that the C-Beam on all ZR-1 have what appears to be bends in two of the diagonal portions. The C-Beams that I removed on all three ZR-1's that I worked on this fall were like that.
Here is the best picture that I could find: Before you decide that your C-Beam has been damaged, lets get some more examples to compare to. I will got check the ZR-1 on my lift right now and report what I find. Don't panic. Jim
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member |
11-06-2009 | #16 |
Re: My clutch issue
I just checked the C-Beam on my 1993 ZR-1. The two "truss" sections that you highlighted in your picture are "bent" on my car. I am sure the C-Beam in your picture is in proper condition.
I could not take a picture of the bends with the C-Beam on the car because the exhaust is in the way. I remember seeing a C-Beam for sale at Corvettes at Carlisle last August and it had the bends also. Jim |
11-06-2009 | #17 | |
Re: My clutch issue
http://www.ultrarev.com The avatars get better.
11-07-2009 | #18 |
Re: My clutch issue
I put a Needle Pilot Bearing in my 90, but i've used both, often. Your choice...either or, not a big deal one way or the other.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
11-07-2009 | #19 | |
Re: My clutch issue
Mine just happens to be out at moment, so here you go. Mine looks the same. Rich
11-07-2009 | #20 |
Re: My clutch issue
I'll be damned.
