Old 10-13-2009   #1
rhipsher
rhipsher's Avatar
Default Need some ideas.
I've got everything back together and ready to go. Plug the key in and all the bells and whistles come on as normal. Turn the key and no start. The lights go a little dim when I try to crank it over which is normal. Three things come to mind. Either a problem with the starter. The new battery I just bought is not fully charged. And 3rd I might have gotten the two plugs that are side by side that plug into that device that bolts onto the under side of the plenum swapped. I fully expected at least one thing to prevent start up. Any ideas?
Old 10-13-2009   #2
Default Re: Need some ideas.
so to understand, it is cranking ( turning over) but not lighting off?
Old 10-13-2009   #3
rhipsher
rhipsher's Avatar
Jeff it's not cranking at all.
Old 10-13-2009   #4
SharkPilot
SharkPilot's Avatar
I don't think swapping the plugs on the ignition module would keep it from cranking.
Have you checked the connections at the battery for cleanliness and tightness? It sounds like you had the plenum off. Did you disturb any of the connections at the starter while it was off? One final thought, how about the clutch switch? I've never had one go bad so I'm not sure, other than not cranking, how it would act.
Hope these ideas help,
SharkPilot
[CENTER][SIGPIC][/SIGPIC]
1991 ZR-1 #1135 Red/Red with both tops.
Stock except for an open topped K&N filter.[/CENTER]
SharkPilot is offline   Reply With Quote
Old 10-13-2009   #5
Jeffvette
It is impossible to make a mistake hooking the DIS module back up. None of the connectors are the same.
There are two connectors on the starter. Make sure you got both of them.
And are you pushing in the clutch pedal?
Old 10-14-2009   #6
tf95ZR1
tf95ZR1's Avatar
Now what would make you think of that?
Old 10-14-2009   #7
rhipsher
rhipsher's Avatar
I've tried a few common sense things. I tapped into the purple wire to see if there is juice going to the starter relay when I turn the ignition key all the way. And it lights up just fine when its turned all the way. I also noticed a red wire coming from another wire harness down behind the plenum and traced it back behind the battery and its been clipped off and just electrical tapped and stuffed behind the battery which I suspect goes to the clutch safety switch. My car starts without having to push the clutch peddle down. I'm going to take the plenum off tomorrow and tap the starter a few times and see if its stuck. Then test it to see if it no good. If that doesn't pan out then I'm really not sure what else to do. It's so close to starting I can taste it but it won't.
Old 10-14-2009   #8
Jeffvette
Pictures of said wire?
Old 10-14-2009   #9
Jeffvette
Originally Posted by tf95ZR1 View Post
Now what would make you think of that?=D>
You just never know
Old 10-14-2009   #10
rhipsher
rhipsher's Avatar
I'll take a pic of the wire tomorrow. I'll just pm you the pic. I'm gonna hit the hay right now.
