09-18-2009 | #1 |
Motor died while running, now no-start
Took the Z out this morning, was running really well - probably the smoothest it has run since I bought it. No sign of any issues for the first 3 or 4 miles. Stopped at a light, then took off gently. got up to 30- 40 mph or so, then nothing - pushed in the clutch and the motor was dead. There was no warning, no stumbling or hesitation.
It cranks just fine, but doesn't fire. Just got a tow back to the house, going to let it cool off a little and start troubleshooting, I suppose... |
09-18-2009 | #2 | |
Re: Motor died while running, now no-start
09-18-2009 | #3 |
You might be on the right track -- no fuel pressure, even though I hear fuel pump priming. Now, this pump has maybe 200 miles on it since new from the partsladi. Filter is also only about 200 miles old.
09-18-2009 | #4 |
Top her Off bro!!!!!!!!!!!!!!!! Let us know a whole team is here to help !!
09-18-2009 | #5 |
Plenty of fuel in the tank -- I can see it in there thru the filler neck. added a gallon anyway -- no different, still zero at the fuel pressure gauge, nothing if I push in on the schrader fitting at the rail.
09-18-2009 | #6 |
Swap the secondary fuel pump as the primary. I think you lost the primary fuel pump. The swap will be the confirmation.
Also the Partsladi is a great vendor. if its new pump I would bet a beer they would replace it for free.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 09-18-2009 at 03:20 PM. |
09-18-2009 | #7 |
09-18-2009 | #8 |
Andrew I dont think so. The Primary pump is the higher of the two you have to physically swap the lower pump within the housing. I am not 100% positive since I have not peformed this job yet. But I am pretty sure thats the only option
The only other Fuel delivery area to look at beyond the pump is the fuel metering block/valve behind the plenum.
09-18-2009 | #9 | |
09-18-2009 | #10 |
Before you get the fuel pumps out, try energizine the fuel pump wire off the main harness. It'll be by the ECM, and be a red spade connector. Hit that with 12V from the battery and see if you get pressure.
What I think you are seeing is the primary is dead, the car ran for the first 5 minutes or so, because the secondary pump was running as well. Once it reaches temp, it shuts the secondary pump off, and will leave you stranded. If you have some electrical pin tools, you can swap the power leads for the pumps in the back. |
