Old 09-09-2009   #1
limey
Default DS Cam Cover removal time cutting step
For those of you that ever have removed the D/S Left Hand camcover, you'll know you probably had to remove the brake booster. In future, remove the L/H engine mount nut & jack the motor up on the L/H side, it allows full clearance of the rear most bolts, eliminating the need to take out the brake booster, which we all know if you've ever doen it, what a major pita that one is.
Takes 5 minutes of work to save 4 hours of grief.
limey is offline   Reply With Quote
Old 09-09-2009   #2
Default Re: DS Cam Cover removal time cutting step
Great tip, thanks for sharing.
Old 09-09-2009   #3
flyin ryan
flyin ryan's Avatar
Ssooo...whatcha' working on?
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 09-09-2009   #4
Heckofa hint!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-09-2009   #5
vettn71
Great tip, Limey! Thanks!!
vettn71 is offline   Reply With Quote
Old 09-09-2009   #6
billybaloneey
billybaloneey's Avatar
I visited Marc H.'s shop last year while on business in the Chicago area. While showing me around the talk turned to cam cover removal. He told me there is a way to remove the left cover without removing the brake booster assembly. I didn't pursue the topic, but the engine mount method must be the way he eluded to.
Thanks for the tip...it sounds relatively easy to do and a time saver too.
Tell all...did you discover it by accident, or were you just looking for a better way?
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
Old 09-09-2009   #7
Kurt!
Schweeet!
Old 09-09-2009   #8
scholtmj
scholtmj's Avatar
Do you jack up the motor in any particular spot or just on the oil pan with a 2x4?
scholtmj is offline   Reply With Quote
Old 09-09-2009   #9
4DSZR1
4DSZR1's Avatar
Great TIP :-) Where do you put the jack?
Thanks
4DSZR1 is offline   Reply With Quote
Old 09-09-2009   #10
DaveK
Thanks
And how much do you need to jack by?
Great tip
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
