Old 09-04-2009   #1
W i l l
Default Pod Gauges
Do any companies sell a pillar pod gauge mount for the C4 to hold three gauges? I have looked but so far have not come up with anything but a 2 holer :-))
TIA,
Will
W i l l is offline   Reply With Quote
Old 09-06-2009   #2
rhipsher
rhipsher's Avatar
Default Re: Pod Gauges
Hey Will! Any luck yet?
Old 09-06-2009   #3
I have only seen 2 for the C4
Old 09-10-2009   #4
W i l l
Rick,
No luck yet. I may have to get a two gauge pillar pod and see if anyone makes a one gauge pod to mount on the dash next to the pillar.
Will
Old 09-10-2009   #5
rhipsher
rhipsher's Avatar
Which one of your Z's is it going into?
Old 09-11-2009   #6
W i l l
Rick,
I am going to put a couple of wide band O2 sensors in the twin turbo car, along with the boost gauge. I might change my mind about the pod gauges, because there really isn´t time to look at gauges when you are under full power in that car. Some time of datalogging tool might be better. Maybe a palm computer hooked up to the widebands.
Will
Old 09-11-2009   #7
rhipsher
rhipsher's Avatar
Originally Posted by W i l l View Post
Rick,
Will
I'll bet that car is a handfull under full power. Brad has a hand held data loger he plugs into his Z and you can play back the runs down the drag strip and that thing shows you what rpm all your shift points where and where your torque curve starts falling off ect. He said its helped him greatly increase his drag times.
Old 09-11-2009   #8
USAFPILOT
USAFPILOT's Avatar
yeah you don't want your eyes inside when you are driving that TT!
