Old 08-25-2009   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default Stiff gas pedal
I took my car out on Sunday and noticed that my gas pedal was really stiff and hard to push down, its esay to push until about a 1/4 the way then it gets really stiff. any idea what could cause this?
-Shaun
1991 Charcoal Metallic ZR1 #730
[URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL]
[URL="http://community.webshots.com/user/shaun91zr1"][/URL]
[IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG]
RiceEatingZR1 is offline   Reply With Quote
Old 08-25-2009   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Stiff gas pedal
Underused??
Old 08-25-2009   #3
Aurora40
Aurora40's Avatar
The throttle plates are progressive, with the first maybe 20% opening just the small primary throttle plate. Then you start to open the secondary plates after that, which are much bigger and have a much stiffer spring.
So to some degree that difference is normal, but perhaps the overall force you are feeling isn't. Open the TB by hand and see if it is abnormally stiff, if not, maybe the cable isn't moving freely?
Bob Saveland
Former owner of #2517
Old 08-25-2009   #4
John Boothby
John Boothby's Avatar
This sounds too simple, but check to see if the throttle is rubbing against the tranny tunnel. Then check the throttle cables. They should have two clamps securing them to the top of the plenum. Then check the throttle body. You may have to remove the cover to check that the cables are properly connected to the throttle plate cams or rod. It could also be that the throttle plates are binding in the throttle body.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
Old 08-25-2009   #5
Ccmano
Ccmano's Avatar
Have you been hiding your Viagra in the gas tank? I hear that can make the pedal stiff... If it stays stiff for more than 4 hours consult a doctor. That's what it says on my package.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-25-2009   #6
Pqtaces
30 mins with the subject of one of Jeffvette's avitars is the perfect cure for a stiff pedal...
[IMG]http://i931.photobucket.com/albums/ad155/pqtaces/pqtaceszr1.jpg[/IMG]
May all your cards be aces and your 0-60 times be sub 5s!
Peter
Pqtaces is offline   Reply With Quote
Old 08-25-2009   #7
H
The Dr. is the last person I'd want to see !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
