Old 08-23-2009   #11
4DSZR1
4DSZR1's Avatar
Default Re: The Lift has Landed>>>
Saaaaaweeeet :-) Very nice
How much room do you have under your Z for maintenance? Is the lifts main purpose to give you one more parking spot?
4DSZR1 is offline   Reply With Quote
Old 08-24-2009   #12
Wow! That is a schweeeet addition to your tool kit!
Old 08-24-2009   #13
Scrrem
Scrrem's Avatar
Hey Michael,
Did you have the link to those step by step directions on the lift setup?
Thanks
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 08-24-2009   #14
ZR1Vette
ZR1Vette's Avatar
Originally Posted by phrogs View Post
I really wanted to get a lift but I think a 2 post is the best way to go, but I looked at a 4 post and my garage is to low for a 4 post, but its too low for a 2 post as well.
But Im wondering who manufatured yours?
Height of the columns was of major concern... could not do a two post lift due to ceiling height (would have had to cut holes into the ceiling drywall to install two post lift)... so I needed a four post lift that had columns that were 84" and that would allow 1 1/2" clearance as the garage door was raised. Many four post lifts have 86"-88"+ columns and then I found the Direct Lift had the dimensions I wanted (column height is 83 1/2" which includes the cable adjuster nut).
http://www.bestbuyautoequipment.com/...20standard.htm
Also the more I read about lift certifications (or lack there of) that came important too...Direct Lift (and Bend Pak lifts) have all the newer certs including 3rd party certifications>>
https://www.bestbuyautoequipment.com...les.asp?ID=133
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 08-24-2009   #15
ZR1Vette
ZR1Vette's Avatar
Yep...a nice addition but once you have a lift (this lift replaces my earlier Snap On scissor style lift) you wonder how you did without one.
Rich...check your email.
Height under car... close to 5' when at its highest position (meaning with mechanical locks engaged)
My primary intent is to use the lift as a service lift... as of this stage can not get my C6 under the ZR (C6 is kept in my neighbors garage since he only has 1 car), but with some modifications to garage door and ceiling can accommodate the lift as a two car storage lift.
Michael
:cheers:
Old 08-24-2009   #16
tdekany
Hi Michael - That lift looks great! That is every detailers dream to work in a garage with a lift.
[B]Paint Correction Specialist - Portland Oregon[/B]
tdekany is offline   Reply With Quote
Old 08-25-2009   #17
rkreigh
the alum ramps are a great idea. I need to do that
I've been "stacking vettes" and love having the lift.
trying to do a garage project for a bit more room. if you all know any good builders and concrete folks in NOVA please let me know.
I'd like to have both a 4 post and a 2 post. they both have nice advantages.
thanks!
95 390 LPE ZR1 (505 rwhp)
