#11 | |
![]() Join Date: Aug 2006
#12 | |
![]() Join Date: Jul 2004
Well I changed the plugs and while It felt a little better anything up in 5th or 5th gear at lower MPH say 40mph and I mash the gas it shakes like the damn car is comming apart. so looks like Ill be in for a plenum pull to see WTF is wrong. Anyone have a tech 1a I could borrow? its the one tool I still don't have.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
#13 |
well heres what I got
I swaped the plug to another cylinder and it was clean in that one, the one in # 6 was getting dirty like carbon or oil? But I checked the wires and coil packs without pulling the plenum and heres what I have. 1/6 20.6 2/3 21.3 4/7 19.0 5/8 20.2 so I guess its time to check the injectors man this sucks.
#14 |
#15 |
Ok now I'm really at a loss
Checked the injectors hot they all rear around 15 ohms. I even changed out the secondary injector relays with my spares and it didn't change anything. now heres the kicker I was hammering on it this evening just now after I did this nice hard pulls untill around 5K and it stumbles but then keeps going but when Im around 60 in 2nd gear I get a SES light. checked the code and Its damn 61 secondary port throttle system WTF ![]()
#16 |
Sometimes 61 is accompanied by an Lean O2 Sensor, I think its code 55.
If its not lean then the ECM is shutting down the secondaries due to insufficient vacuum, so differential MAP sensor is sending a signal voltage to the ECM of less than .7v if IIRC. Secondary vacuum leak? Weak Fuel Pressure? ![]() ![]() |
#17 | |
![]() Join Date: Aug 2008
![]() Last edited by rhipsher; 08-17-2009 at 12:06 AM. |
#18 | |
Im thinking about just removing the secondaries, I mean I do not have smog check so I really don't care about them being there.
#19 |
#20 |
that was the problem on both cars . that little deal with the filter on it .i have a sppare if you cant find one
