Old 12-29-2005   #1
haber rj
Default Stress Bar
I think that is the name of the bar that is available from Ecklers, that stiffens up the rear of these cars, are they easy to install and do they really help. I am trying to find a way to take as much flex out of the car as possible, has anyone used this item.
Thanks haber rj
haber rj is offline   Reply With Quote
Old 12-30-2005   #2
ZR1 MK
Default Re: Stress Bar
What Stress bar?
I have the stock type X Brace, but this aftermarket brace is better.
http://www.r-dracing.com/CROSS-FRAME.htm
Mike
427 cu in LT5
[URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL]
ZR1 MK is offline   Reply With Quote
Old 12-30-2005   #3
Jerry#397
Jerry#397's Avatar
I have seen the stress bar used on two C4's at recent Auto-X events; talked with both owners and they both recommended them for Auto-X.
Jerry
Jerry#397 is offline   Reply With Quote
Old 01-03-2006   #4
haber rj
Thank you all for thefollow up information, but the brace that I have seen is the one that goes behing the seats and attaches to where the seat belts are ankered. This bar has the mounts for the fire extingusher & a camera.
haber rj
Old 01-03-2006   #5
Jeffvette
You mean a harness bar, which is what they are normally called. I had one until i went to a 4 pt roll bar. They are nice and will help eliminate a few squeeks and rattles. The main draw is they give you a place to put a harness.
Old 01-03-2006   #6
haber rj
Thank you for correcting me on the name, so I guess that if you aren't going to use a harness it would be a waste of money, or it would just be cosmetic.
haber rj
