Old 06-09-2009   #21
Default Re: carter200's CNC machining is............
Yes, much more controlable over rough roads, car did not dart like it did before
Yes, front shocks are the new pair that was on eBay for $150.. I had those grooved for the shocks
I need too get good pictures but the front is lowered 1.5" and the rear (still has the fiberglass spring) is lowered 1.25"
Hmmm, Another future project.
Thanks.
Old 06-09-2009   #22
One major concern I have over supension mod is that, based on what I understand, changes in spring rate and/or roll bar can result in under steer/over steer characteristic.
Will you be testing and tweaking?
Old 06-09-2009   #23
probably tweaking, I need to finish my poly bushing install and get the car aligned.. then I will see how well it does
Old 06-09-2009   #24
Please keep us updated.
Old 06-09-2009   #25
will do.. keep in mind.. it is a slow going process with me
Old 06-17-2009   #26
bobbyhi
bobbyhi's Avatar
Forgot to post some pics of the air filter bolts that Carter made - hope this works
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 06-17-2009   #27
DaveK
Very nice Bob! And Carter!
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 06-17-2009   #28
carter200
carter200's Avatar
Thanks Bob and DaveK Bob, you gonna line em up or let em end up where they will? Either way they look nice. Thanks again
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-18-2009   #29
rkreigh
how is the ride in comparison to before
I went with 400 front, and 275 back and the ride is OK, but I think the F1 supercars are the "problem"
biggest thing I ran into is lowering the car too much. not good. I think I was bottoming out the shocks as I busted a fx3 controller
I'd like to someday upgrade to a better shock and maybe lose the fx3.
more hassle than it's worth to me.
nice setup!! that's a great way to go as coil overs are expensive and you really engineered a bargain conversion
FYI, DRM grooves the shocks pretty reasonable for the snap ring. a local machine shop quoted me 200 and DRM was 15 per shock as I remember (call randy)
as for tuning, it's hard to "out engineer" the Gm engineers and the stock suspension is actually a pretty good compromize for street driving, but the coil overs definely help
there is a bit of hassle getting them on there and setup, and because I'm so lazy I wouldn't have done it again knowing what I do now, but I mostly didn't like the expense and the harsh ride. there is no doubt the car is "glued down" better and much more stable at speed around corners.
my c5 has coil overs, but rides like a cadillac in comparison
alot of that is the EMTs though, when I bolt on my "race tires" with the a molds, ride is much better.
95 390 LPE ZR1 (505 rwhp)
Old 06-18-2009   #30
Ron,
How low did you go? I have not noticed if it bottoms out, but the stance it very close to what my 89 was.. it seems much better.. as for the ride, I have not driven enough to say how it really is.. I have one more component to swap, then get an alignment.. Not sure i will get the new parts on this weekend but I am hoping to
