Old 12-15-2005   #1
ralph92ZR1
ralph92ZR1's Avatar
Default Brake Bleeding Advice
I bought my '92 ZR-1 in March '05 with 12,000 miles and have since added 3500 -fun miles. I traded a '69 that I had completely rebuilt the calipers and brake system, i.e. I saw the damage done by not changing brake fluid. I am looking for advice because when I checked with my dealer they said "with the new calipers " fluid does not really need changing. That may be the same as "if not broke-let it alone". Must a pressure bleeder be used?? Any issues with the modulator if no air has entered the system??
Thanks for advice given...
[FONT=Franklin Gothic Medium]Ralph E. Weise [/FONT]:)
'92 ZR-1#473
Red/Red
ralph92ZR1 is offline   Reply With Quote
Old 12-15-2005   #2
cwmoss
Default Re: Brake Bleeding Advice
Ralph,
It is a VERY good idea to regularly change the brake fluid. I had a 2001 Z06, that had only 2900 miles on it when I bought it, but it was about 4 years old. I bought one of the Mini Vacs. You can get them at Harbor Freight and other places for about $40.00. What you do is first get a turkey baster and suck most, not all, of the fluid out of the reservoir, fill it with new fluid. Then go to the CLOSEST caliper, attach the flex line to the bleed screw, then pull a vacum with the mini vac, and crack the bleed screw and it will suck the disgusto fluid out. Do this until all you see is good clean fluid. Remember to check the reservoir so you don't get too low. Then go to the next closest caliper and repeat( 1.Left-front, 2. right-front, 3. left-rear, 4. right-rear.) It's a one man job. After I bought my ZR1 a few months ago, that was the first thing I did after changing the oil. It was a snap the second time around. The moisture in the system will rust the lines from the inside out. I had a '67 big block car that I bought back in 1983 and it had brake problems. So I bought a SS kit from one of the vendors and when I started taking the original stuff off, the lines just came apart. Good Luck !!!!
cwmoss is offline   Reply With Quote
Old 12-15-2005   #3
DOT #5 my mech. swears by it and upgrades it for all of his rides incld his 98 vert. All the exotics use it...must be a reason why ya think!!!!
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 12-16-2005   #4
Bleeding the fronts is very easy and quick since you don't have to remove the wheels, just raise the hood and you have access to the bleeders. Jacking up the back end, removing, and reinstalling the rear wheels takes most of the time to complete the job.
Old 12-16-2005   #5
Bill
Bill's Avatar
I had read that Dot 5.0 brake fluid was silicone based and as such is not compatible with our ABS equipment. I know that silicone based brake fluid is more moisture resistant. Higher numbers (5.1 & 5.2) were ok. Has any one else heard this, any comments? The most frequently recommended fluid is (no flames please) Ford Blue brake fluid.
[img]http://home.comcast.net/%7Ebsoomann/srsig.jpg[/img]
Bill is offline   Reply With Quote
Old 12-16-2005   #6
ralph92ZR1
ralph92ZR1's Avatar
Thanks...makes sense and I appreciate the help.
'92 ZR-1#473
Red/Red
Old 12-16-2005   #7
cwmoss
I agree, Dot 5 is Silicone and for the earlier "NON ABS" cars.
Old 12-17-2005   #8
well that raises a ? then. is 5.1 and above really that much different than 5.0
Old 12-17-2005   #9
Bill
Bill's Avatar
Brian, now your making me work. I was not sure either so I found this:
Stolen from the Airheads BMW Club newsletter - July 1995
Battle of the DOTs
DOT 3-4 Verses DOT 5. Which brake fluid should I use?
From Oak Okleshen #35 "With regards to the DOT 3-4 verses DOT 5 brake fluid controversy, here is an article sent to me by Mr. Steve Wall. It is one of the most professional treatments I have seen on the subject".
[I had to condense this article from 6 pages to 1 due to space limitations -ed]
Brake Fluid Facts
by Steve Wall
As a former materials engineering supervisor at a major automotive brake system supplier, I feel both qualified and obligated to inject some material science facts into the murky debate about DOT 5 verses DOT 3-4 brake fluids. The important technical issues governing the use of a particular specification brake fluid are as follows:
1. Fluid compatibility with the brake system rubber, plastic and metal components.
2. Water absorption and corrosion.
3. Fluid boiling point and other physical characteristics.
4. Brake system contamination and sludging.
Additionally, some technical comments will be made about the new brake fluid formulations appearing on the scene.
First of all, it's important to understand the chemical nature of brake fluid. DOT 3 brake fluids are mixtures of glycols and glycol ethers. DOT 4 contains borate esters in addition to what is contained in DOT 3. These brake fluids are somewhat similar to automotive anti-freeze (ethylene glycol) and are not, as Dr. Curve implies, a petroleum fluid. DOT 5 is silicone chemistry.
Fluid Compatibility
Brake system materials must be compatible with the system fluid. Compatibility is determined by chemistry, and no amount of advertising, wishful thinking or rationalizing can change the science of chemical compatibility. Both DOT 3-4 and DOT 5 fluids are compatible with most brake system materials except in the case some silicone rubber external components such as caliper piston boots, which are attacked by silicon fluids and greases.
The big bugaboo with DOT 3-4 fluids always cited by silicone fluid advocates is water absorption. DOT 3-4 glycol based fluids, just like ethylene glycol antifreezes, are readily miscible with water. Long term brake system water content tends to reach a maximum of about 3%, which is readily handled by the corrosion inhibitors in the brake fluid formulation. Since the inhibitors are gradually depleted as they do their job, glycol brake fluid, just like anti-freeze, needs to be changed periodically. Follow BMW's recommendations. DOT 5 fluids, not being water miscible, must rely on the silicone (with some corrosion inhibitors) as a barrier film to control corrosion. Water is not absorbed by silicone as in the case of DOT 3-4 fluids, and will remain as a separate globule sinking to the lowest point in the brake system, since it is more dense.
Fluid boiling point
DOT 4 glycol based fluid has a higher boiling point (446F) than DOT 3 (401F), and both fluids will exhibit a reduced boiling point as water content increases. DOT 5 in its pure state offers a higher boiling point (500F) however if water got into the system, and a big globule found its way into a caliper, the water would start to boil at 212F causing a vapor lock condition [possible brake failure -ed.]. By contrast, DOT 3 fluid with 3% water content would still exhibit a boiling point of 300F. Silicone fluids also exhibit a 3 times greater propensity to dissolve air and other gasses which can lead to a "spongy pedal" and reduced braking at high altitudes.
DOT 3 and DOT 4 fluids are mutually compatible, the major disadvantage of such a mix being a lowered boiling point. In an emergency, it'll do. Silicone fluid will not mix, but will float on top. From a lubricity standpoint, neither fluids are outstanding, though silicones will exhibit a more stable viscosity index in extreme temperatures, which is why the US Army likes silicone fluids. Since few of us ride at temperatures very much below freezing, let alone at 40 below zero, silicone's low temperature advantage won't be apparent. Neither fluids will reduce stopping distances.
With the advent of ABS systems, the limitations of existing brake fluids have been recognized and the brake fluid manufacturers have been working on formulations with enhanced properties. However, the chosen direction has not been silicone. The only major user of silicone is the US Army. It has recently asked the SAE about a procedure for converting from silicon back to DOT 3-4. If they ever decide to switch, silicone brake fluid will go the way of leaded gas.
The single most common brake system failure caused by a contaminant is swelling of the rubber components (piston seals etc.) due to the introduction of petroleum based products (motor oil, power steering fluid, mineral oil etc.) A small amount is enough to do major damage. Flushing with mineral spirits is enough to cause a complete system failure in a short time. I suspect this is what has happened when some BMW owners changed to DOT 5 (and then assumed that silicone caused the problem). Flushing with alcohol also causes problems. BMW brake systems should be flushed only with DOT 3 or 4.
If silicone is introduced into an older brake system, the silicone will latch unto the sludge generated by gradual component deterioration and create a gelatin like goop which will attract more crud and eventually plug up metering orifices or cause pistons to stick. If you have already changed to DOT 5, don't compound your initial mistake and change back. Silicone is very tenacious stuff and you will never get it all out of your system. Just change the fluid regularly. For those who race using silicone fluid, I recommend that you crack the bleed screws before each racing session to insure that there is no water in the calipers.
New developments
Since DOT 4 fluids were developed, it was recognized that borate ester based fluids offered the potential for boiling points beyond the 446F requirement, thus came the Super DOT 4 fluids - some covered by the DOT 5.1 designation - which exhibit a minimum dry boiling point of 500F (same as silicone, but different chemistry).
Additionally, a new fluid type based on silicon ester chemistry (not the same as silicon) has been developed that exhibits a minimum dry boiling point of 590F. It is miscible with DOT 3-4 fluids but has yet to see commercial usage.
here is the link where I found it
http://www.xs11.com/tips/maintenance/maint1.shtml
We all know about the reliability in web info, so I'll keep looking.
Old 12-17-2005   #10
GREAT POST BILL!!!! Looks like my best friend/mech of mine WILL NOT BE PUTTING DOT 5 IN MY ZR-1!!!! I too did a search of the zr-1 list serve and a recent post by KIM L. that she went with the super dot4 new ones and was happy....Jeeeze why does it always have to be so complex???? ok guys this this the time to chime in and let us know what is workin out there in the real zr-1 world......WE WANNA KNOW WHAT DOT UR USING ON YOUR ZR-1!!!!! AND WHY AND HOW HAVE YOUR RESULTS BEEN!!!
