#11 |
![]() Join Date: Aug 2006
#12 |
My guess will be an O2 sensor code. Steady state cruise.
#13 |
![]() Another strong candidate I was wondering if a backfire event blew off the MAP sensor hose but thats normally a upon cranking issue instead of a steady cruise.
#14 |
![]() Join Date: Nov 2007
![]() ![]() BTDT a few times. At the risk of sounding like a broken record, a scanner (next to your dog) is your best friend! Best money I ever spent, but it was a little more expensive than a paper clip (and easier to use when driving down the road that a clip is too). ![]() ![]() ![]() But, my guess would be a lazy O2, based on the number of times I've seen it cause the same symptoms described. (Can we say low cross-counts?) P. |
#15 |
![]() Join Date: Jul 2005
Steve,
My buddy has a 04 ZO6, on a recent trip to Vegas he decided to use the Nitrogen Shell V-power. After two tanks full the "check engine light" comes on. Read the codes and it was a O2 code. Filled the tank the third time with Chevron Prem. and within 40 miles the "check engine light" goes out and has not come back on. Does the Shell fuel clean too much? Note: I had no trouble running the Shell fuel? Thanks, Jerry 93 #397 |
#16 | |
