Old 12-09-2005   #1
ZR-1 Mack
ZR-1 Mack's Avatar
Default Looking for a 1991 ZR-1 Full Power Bypass Harness
Looking for a 1991 ZR-1 Full Power Bypass Harness. Not really interesting in swapping chips.
The harness is no longer offered in all the catalogs I have but maybe someone has one they never installed.
ZR-1 Mack is offline   Reply With Quote
Old 12-21-2005   #2
ZR-1 Mack
ZR-1 Mack's Avatar
Default Re: Looking for a 1991 ZR-1 Full Power Bypass Harness
Doesn't look like I have any choice .After checking out my chip and finding out its stock, I will probably now just change it out this spring and have it programmed so the power key is turned on.
ZR-1 Mack ... 91 ZR1 Black/Black #487 NY
Old 12-22-2005   #3
yellowz
mack
im confused as what you are asking a full power bypass harness???if you order the switch for the 91/95 this comes as an assembly,unless you mean the harness to the ecm????and also i just checked on the rear bumepr cover
gm has not yet discontinued this they have no stock but i can get one using a vin an assigning a spac case..
peter
yellowz is offline   Reply With Quote
Old 12-28-2005   #4
ZR-1 Mack
ZR-1 Mack's Avatar
Peter,
In Mid America Motor Work there is a Full Power Bypass harness for 92-95 ZR-1s P/N 609-151 in the C4 catalog
In earlier catalogs there was also one offered for 90-91s. The harness for the 90/91s is now discounted by Mid America, Corvette America and Ecklers.
Since I can't find one I'm just gonna go to a new chip where the full power key will always be on .
Old 12-28-2005   #5
ZR-1 Mack
ZR-1 Mack's Avatar
[quote=yellowz]mack
Peter ... Thanks for the info. Limey from Whites Racing Products was on another forum and mentioned this. I didn't try to order one... so that's good news.
I hope I never need to buy one!
Old 12-30-2005   #6
LGNDLT5
LGNDLT5's Avatar
The harnees that is/was offered by at least one of the catalogs was designed by Gordon Killebrew. If you need assistance he would be the man to speak with. If he can't provide one he can certainly help you source one. Good Luck. John
LGNDLT5 is offline   Reply With Quote
Old 12-30-2005   #7
ZR-1 Mack
ZR-1 Mack's Avatar
Thanks John...That's a great idea. I have some time this weekend and will send Gordon an email. I need to find out if he will be at Carlisle again this year anyway.
I'll let you know what happens.
Ron
