Old 04-28-2009   #21
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Closed Deck
Hey Al,
How about giving us an update on this project?
Did the close deck approach meet all of your expectatioins?
Old 04-28-2009   #22
ALZR1
Hey Al,
The motor runs great and i'm still putting miles on her.No leaks at all,however
I just finished building A breather box for it that's over 3 QTS with two pcv's
so the motor relieves itself of crankcase pressure.I'm setting up A dyno time
so I can finish tuning and get some numbers,i'll keep you boys posted.
AL.
ALZR1 is offline   Reply With Quote
Old 04-28-2009   #23
AL.
Al,
Can we come and watch?
Old 04-29-2009   #24
flyin ryan
flyin ryan's Avatar
AL.
Did you consider using an electric vacuum pump instead? Would make more power...especially when the cubic inch numbers go up.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 04-29-2009   #25
VetteMed
Impressive... Very Nice!
Old 04-29-2009   #26
ALZR1
Ryan I'm considering installing A Mechanical vacuum pump since I removed
the AC compressor,it should fit.
AL.
Old 04-29-2009   #27
flyin ryan
flyin ryan's Avatar
AL.
Do it if you can, you won't regret it. Good chance it will fit, based off a Moroso pump (I wouldn't use anything else personally), just make sure to size the pulley(s) correctly, they don'y like to be spun too fast, 6500 RPMish. I suggested the electric pump just for ease of mounting, no pulley's to deal with, can hide it pretty good, that sort of thing but all things being equal if your willing to do the initial work, Mechanical is what i would like to see on a semi-maximum effort combo.
Old 04-30-2009   #28
Bob G
Which electric pump will work ?
Bob G
Bob G is offline   Reply With Quote
Old 04-30-2009   #29
Pete
Pete's Avatar
Bob G
Got my attention.
Plus what kind of vacuum can we get from electric pump.
I was going to try and fit a Moroso.
I see www.GZmotorsports.com have a comlete bolt on kits for lsx motors.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-14-2011   #30
flyin ryan
flyin ryan's Avatar
Post Little late...Oopps, sorry
Got my attention.
Pete
Reading this it looks like I was asked a question & never answered, sorry bout' that ...Not sure how that happened .
Can get an Electric Vac. pump from Engine Works, I can get the number if any of you need, (basically a GM smog pump) & you'll see 3"-4". Not a ton, but if you have a positive crankcase pressure situation, can make the world of difference.
I wouldn't recomend the GZ pump. Go Moroso if going mechanical.
