04-16-2009 | #1 |
recoating/plating stock top end bolts anyone done it?
I have used the SS bolts but I was thinking about putting my spare engine up for powder coat treatment and I was thinking of using the stock hardware, does anyone know of a good place to send these bolts for black oxide coating like the factory did. I have plenty of hardware so no worries about striped heads
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
04-16-2009 | #2 |
Re: recoating/plating stock top end bolts anyone done it?
Not the same but Gun Blueing looks good & is pretty durable, might want to give it a try, Johnny. I use it in similar situations.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
04-16-2009 | #3 |
Well I tryed that stuff that eastwood sells and it doesnt work very well so I was thinking about just sending them off.
Ill check out the gun blueing as well.
04-17-2009 | #4 |
You dont have to go to the hassle of sending them out,bead blast the bolt heads and blow some satin black on them.Ive got an air brush Ive used for this and it works like a charm.Once the bolts are painted bake them in an oven at about 150 degrees for 1/2 an hour and your good.
04-19-2009 | #5 | |
04-20-2009 | #6 |
I've done that in the past also, works so-so/o.k., do it outside if you can...stinks like a B**ch.
