Old 03-18-2009   #171
GregCrowe
Default Re: 91 ZR-1 Cutting Out Under Load
Greg,
Try fitting some spade lugs in the slots and then connecting Ohmeter to them.
Spades wouldn't even fit up in those tiny slots. I did however use some wires.
Testing of the original GM coils got me:
Primary / Secondary
1. .6 ohms / 5.63 k-ohms
2. .6 ohms / 5.57 k-ohms
3. .6 ohms / zero
4. .6 ohms / zero
All the stock coils look fine on the primary readings. The secondary readings do look suspect.
I'll try to pull the Summit/Accel coils and get a primary reading on them today if possible.
GregCrowe is offline   Reply With Quote
Old 03-21-2009   #172
GregCrowe
I bought a set of brand new GM ZR-1 D545 coils.
So.........More coils, more tests:
Summit/Accels :
Primary / Secondary
1. .7 ohms / 7.02 k-ohms
2. .6 ohms / 7.06 k-ohms
3. .6 ohms / 7.06 k-ohms
4. .7 ohms / 7.00 k-ohms
Brand New GM D545's
1. .5 ohms / 5.71 k-ohms
2. .5 ohms / 5.64 k-ohms
3. .5 ohms / 5.66 k-ohms
4. .5 ohms / 5.66 k-ohms
The one thing I did notice on the Summit Accel coils was that the slots on the bottom of each coil(that the 2 spade terminals plug into) were bigger and more loose than on the GM coils. They definitely don't make a nice tight connection. That may be the problem.
I should have the car back together tomorrow and we'll see if it's fixed.
Old 03-22-2009   #173
GregCrowe
IT'S FIXED !!!!!!!!!!
Yes folks, my ZR-1 is running like a champ again. New GM D545 coils fixed the problem. The high rpm power is awesome. No cutting out, no miss, no falling on it's face.
For the record, let it be know that SUMMIT/ACCEL COILS SUCK !!!!!!
These are absolute JUNK !
I will be having a nice conversation with Summit tomorrow.
I would like to thank everyone out here for their help over the past 3 years and especially JeffVette.
Old 03-22-2009   #174
Jagdpanzer
Jagdpanzer's Avatar
Congratulations Greg!!
The entire ZR-1 brotherhood applauds you!
Your perseverance, determination, and resourcefulness have finally paid off.
34 months, 173 posts, 8,600 looks later and the problem is now solved
....and at the end you got it right about the coils.
I almost picked up a set of Accels a while back for spares but went with the MSD 8224's instead. Just checked them and they meg out the same as your new set of GM D545's.
Old 03-22-2009   #175
Jeffvette
Glad to hear Greg. Go and give summit hell.
Old 03-22-2009   #176
gbrtng
gbrtng's Avatar
Is the LT5 coil a common GM part?
Old 03-22-2009   #177
GregCrowe
Very common. GM D555 or D545. I have no idea what the difference is between the 2 part numbers. It's the same coil as used on almost every GM V6. 3 coils on the V6, 4 on the ZR-1 V8.
Old 03-22-2009   #178
GregCrowe
I may have figured out the difference between the GM D545 vs the GM D555 coil. The D545 lists for 70 cents more than the D555. It looks like the D545 comes with a little rubber gasket a hair over an inch long that goes around the 2 pin connectors under the coil. From best I can tell, the D555 comes without the rubber gasket.
Old 03-22-2009   #179
Damn awesome !! Makes me feel better I changed out mine with GM replacements as well when I had the top end done. Damn gald to hear you chased that problem down!! I considered going the Summit route as well
Old 03-23-2009   #180
tccrab
tccrab's Avatar
Good Job Greg!
I commend you for your perseverance.
I personally would have given up hope after only a month or two, but you've hung in there for nearly 3 long years.
Simply Amazing.
Now, get in it and.....
DRIVE IT LIKE YOU STOLE IT!!!
Congratulations, my hat is off to you.
Long live the beast.
TomC
"Crabs"
