02-20-2009 | #1 |
Help 91 Random Tech or Magnaflow cats Part number
Need a little help. I believe that I lost my drivers side cat this week. Sounds like a chock full O nuts around the resonator area. Figures as emissions is due on the 15th frankly the last 30 days of my life have been pure hell so it figures. Does anyone know the correct part numbers for the Magnaflows and the Random tech cats? I beleive the part numbers for the Magnaflows are 94006 for both sides but I am not sure. Im tired of dorking around with used cats so it maybe time to hang the set of JEALs. If anybody knows this off the top of thier heads PLMK and thanks GC
02-20-2009 | #2 |
Re: Help 91 Random Tech or Magnaflow cats Part number
Gold One, if you do the switch to an AF cat and the Jeals you have been sitting on, I have 4 new stainless steel 3 inch reduction pipes that will make fitting to your exhaust much easier. May save extensive cutting and piecing. I have about $80 in the pieces but will take $40 plus cheap shipping for them. Best money you will ever spend. Makes headers and cats fit like factory.
G.
1991 ZR-1, Black, Black, # 541 |
02-20-2009 | #3 | |
Awesome Greg is this needed because the Jeals are a three inches on the down pipe side and I beleive my Corsa system is a 2.5? If so sold and thanks Greg as I said its been a tough month!!!! Also update!! The Car failed emissions and the coffecan full of nuts and bolts is getting louder I think the Drivers side cat ran out of it lives. Does anybody here have a set of aftermarket cats they want to get rid of? Either model best price I have found yet is $65 each for the MFs.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-21-2009 at 01:06 AM. |
02-20-2009 | #4 | |
02-20-2009 | #5 |
daryl .,just a word of caution .if that cat has started to break up ,please be carefull as the cat material can work its way back into your motor with very bad results .just didnt want anything bad to happen to your motor . with you having a bad month didnt want to see one more thing go wrong .
02-20-2009 | #6 |
Just a FYI for anybody searching in the future here are the numbers
MPE-59959 7.75" length MPE-59929 11" length 3 inch in, 3 inch out metallic substrate |
02-20-2009 | #7 |
Here is an example of 3" Magnaflow MPE-59959 7.75" length cats connected to a 2.5" Corsa system using Stainless Works SS transitions http://www.stainlessworks.net/cart/p...oducts_id=1295
02-20-2009 | #8 |
Thanks for that illustration. Thats what I was thinking it would look like. Ok update im going with the Jeals and I was able to pickup a set of Magnaflow cats 59959s for $137.36 Shipped. Let see if I get a performance pick up on this after this is done as well.... and pass emissions. Thanks for all the help. GC
02-20-2009 | #9 |
I like those transitions
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
02-20-2009 | #10 | |
George |
