02-04-2009 | #1 |
Clutch slave.
I'm having the worst time trying to find a slave cylinder. They are obsolete with most parts houses. Napa, Advanced, Auto zone. They show obsolete on there computers. I'm almost tempted to put the original first one back in. I just don't know how to bleed it. There's no way to get ahold of the bleed screw. It looks like its been cut off.
02-04-2009 | #2 | |
Re: Clutch slave.
easier to work what and bleed screw will not break off like the 89-90 models 91-96 is more readily avail.. L98/LT1/LT4/LT5 slaves are all the same
02-04-2009 | #3 |
Re: Clutch slave.
yeah Rick...on the later model the bleed screw is on the bottom...if I rememebr correctly from doing mine. Either that or I put it on upside down.
02-04-2009 | #4 | |
Re: Clutch slave.
I had to do my clutch R&R by myself on my '91. OH yea, FUN, FUN. (BTW, thanks for all the pics you posted), but ...even with the later style bleeder screw on top, it was also a pain to get it bleed because of the tight fit and wrench room. I am still not sure I got 100% of the air out. For the first time I can remember, I committed the sin of letting the reservoir run dry. I also read a lot of comments about just having to let the last bit of air work it's way up & out so I just kept working the clutch. I swore that if I had to do it again, I would try and install one of those spring loaded self bleeder in there if possible. Another note, you may not have read about yet concerning the badly designed/machined replacements. IIRC, the internal orifice was too small to release the piston and a burr chewed the new o-ring? Let me know If you need any help neighbor, I am on the NW side of town near 610. Lee
An Unarmed Citizen is a Future Peasant. Something BLOWbama & Hilary are trying to accomplish now at the UN with the "Global Small Arms Treaty" |
02-05-2009 | #5 |
Re: Clutch slave.
I let the reservoir bleed dry at first when I changed mine as well...what a pita. If I was at home I would look under there and see whether or not the bleed screw is on the top or bottom all I know is it was a pita. I still need to figure out why my shifter is rattling.
02-05-2009 | #6 | |
Re: Clutch slave.
02-05-2009 | #7 | |
Re: Clutch slave.
02-05-2009 | #8 | |
Re: Clutch slave.
I am about to get serious about investigating some serious chug-a-lug symptom mine developed when I nail it. I just figured it would be a secondary vacuum thing, but when it still does it with the key off I am starting to pucker up just thinking about an electrical problem. Anyway, I read you are a CNC machinist, it seems we share some interests although I don't remember any G-Codes anymore and was just a job shop manual machinist for a short while, you can appreciate how it can get in your DNA for life. I would like to yak with you sometime so if would PM me your phone number and a message of when it would be the best time to catch you with some free time. Lee
02-05-2009 | #9 | |
Re: Clutch slave.
Greetings USAFPILOT, I have read plenty of your posts over the years, thanks. I am sure you helped me out with something without knowing it? call me Lee. It seemed about two pumps is all you get? My '91 was on top, with a melted rubber cap from the heat.
02-05-2009 | #10 |
Re: Clutch slave.
Rick, before running enough fluid through it to flush out, it might be a good idea to use teflon tape to seal the threads better and run a piece of clear tubing up and back into the clutch master cylinder or another clear container above the cylinder. Then barely (and I mean just barely) crack the bleeder screw to see if any air after a few pumps. WITH another set of eyes watching the level that is.
