Old 02-04-2009   #21
kenthompson
kenthompson's Avatar
Default Re: Ignition channels
Summitracing shows
MSD-8870 @ 36.95.. you need 4
MSD-62152 DIS 4 Plus ignition $569.95
Plus ~ 43 x 4 ea for the coils, if you change them.
Plus ~ 79 for Wires (add the terminal kit because MSD wires fit like a red-headed stepchild and will need to be trimmed)
Holy crap, would it have been cheaper to finance a new ZR1?
kenthompson is offline   Reply With Quote
Old 02-04-2009   #22
I think a LS1 Ecm could be made to work with those that have removed secondaries
As for the cam sensor, all it does is tell you when you are at #1 ( or TDC) one of the 2.. it is just for sync.. nothing else
=Jeff=
What's your thought regarding the CCM/ECM comm issue? You think the
LSx PCM can be made to communicate? I'm not sure it will be "trivial". This is the issue EFI Connections ran into when trying adapt the LSx PCM to run LS coils on LT motors.
Old 02-04-2009   #23
=Jeff=
Leave the old ECM in on powered to communicate with the CCm to alleviate the code.. use the Old ECM for that purpose only..
