Old 01-29-2009   #1
Bob Seliga
Bob Seliga's Avatar
Default Radiator
I received a price of $389 for a new aluminum radiator from Entropy Technology Corp. Has anyone heard of these guys. If so any comments would be appreciated.
Bob Seliga is offline   Reply With Quote
Old 01-29-2009   #2
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Radiator
I don't know what your application is but you get get a NOS one from partsladi on ebay for $130.
Old 01-29-2009   #3
Many say Ron Davis is the best radiator, but many have gotten Dewitts as well.
If you need the best cooling and have the means.... I would go with either of them.
Old 01-29-2009   #4
QB93Z
QB93Z's Avatar
The OEM radiator that is offered by thepartsladi is made by Delphi. It will fit in a ZR-1, but be aware that it is the radiator that is used in C4 Corvettes with an automatic transmission. The radiator has two fittings on the right side tank and a transmission cooler inside the right tank that are not on an original radiator for a manual transmission car.
This pic shows one of one of the extra fittings and you can see the "cooler" in the outlet pipe.
The radiator will fit perfectly in a ZR-1 and the extra fittings cannot be seen when the shroud is installed.
I am not familar with the radiator that you mention in the OP. The important question for any after-market radiator is the fin area thickness. both the DeWitts and the Ron Davis radiators are thicker that the stock radiator. They require either trimming the fan shrouds by cutting off 5/8 inch of material, OR installation of spacers to hold the fan shroud away from the radiator core. (Ron Davis recommends cutting, see their web site, and DeWitt sends the spacers)
Here is a picture of my LT5 with the spacer in place:
I hope this helps.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 01-29-2009   #5
PhillipsLT5
PhillipsLT5's Avatar
I went with Fluidyne
Old 01-30-2009   #6
I hope this helps.
Great postup and Jim is 100% on target with his response. When I changed mine out last summer I went with the OEM Delphi model and the change in cooling performance is impressive. Hell I bought it from a forum member for $80 shipped to my door how could I go wrong as it was brand new. The OEM radiators work perfectly fine. As Jim stated they will show up as a universal fit due to fact that some C4s had automatic transmissions but you simply dont use those fitting as Jim also stated.
The main issue is after 17 years of filth, sand, grit and road grime, bent cooling fins, loose paper bags, Leaves, cigarette butts etc build up on, in, around the shroud area and the radiator itself fails.
All a larger radiator does is buy you more cooling time if your stuck in heavy traffic and lesson recovery time due to the extra capacity. About the best feature of an all aluminum radiator is the lack of the plastic end caps but unless you a fulltime track racer its just not needed and I live in Arizona and can tell you a new OEM radiator that is maintained will provide ample cooling capacity for any C4
Now back to your question. I have never heard of that brand before but if I was going to go with an aftermarket alternative I would go with either the Dewitts or Fluidyne as listed by Jim and what Phil uses. I am not a fan of spacers or cutting the shroud but hey thats me.
Old 01-30-2009   #7
Bob Seliga
Bob Seliga's Avatar
Thanks Guys,
It looks to me like Dewitts is the best deal. I'll be ordering within the next couple of weeks - got other projects underway right now.
You guys should think about comming to Spring Mountain in March for the Corvette Track Days. I need some help whipping up on the newer cars.
Old 02-01-2009   #8
lbszr
lbszr's Avatar
Thanks Guys,
Sure Spring mountain would be good but too far for me!
Think A Dewitt's will be in mine soon from all the info posted and I'd rather do spacer's than cut.
Let me know if the Dewitt's help's on the track. Above 80 deg. had to back off for cool down on mine, but it would cool down fast when backed down.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
