12-14-2008 | #1 |
Fluidyne Radiator for Automatics
I just bought a Fluidyne radiator. The order was for a radiator for manual transmission but they sent a radiator for automatic transmission. Does anybody know if this will fit without any problems? Any information will be appreciated.
12-14-2008 | #2 |
Re: Fluidyne Radiator for Automatics
I do not know if the Fluidyne radiator will fit properly in a ZR-1, but I just replaced the radiator in my Red 1990 ZR-1 and I can offer some insight.
First, the Fluidyne radiator with the auto transmission cooler is probably identical to the radiator for manual transmission cars except it has the trans cooler added to the right end tank. The auto trans cooler connections are NOT visible at all when the radiator is installed in the car. Here is a picture of the DeWitts radiator I installed so you can see the difference in a radiator without the auto trans cooler. Are you planning to install the radiator yourself? If so, I just did it and I can offer advice if you want it. Jim
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member |
12-14-2008 | #3 |
I believe some of the cooling area will be replaced with the trans fluid cooler, so you may want to return it and get the right one.
Generally speaking they should fit the same, the only GM one now available has an A/T cooler on it yet people put them on their Z's no problem.
12-14-2008 | #4 | |
My observation is: for just about every C4 Corvette that has cooling problems and > 50,000 miles, the radiator fins will be clogged with debris and any replacement radiator will GREATLY improve engine cooling. Jim
12-14-2008 | #5 |
I installed a GM replacement radiator this year and as pictured that was setup the same way for both both auto and MTs. It will fit fine from the picture you posted, just the AT lines are not used. The cooling will not be affected and as stated you should not have any cooling issues for years to come.
A friendly word of advise the lower rad hose is at an extreme angle that if your switching to Samco hoses at this time the only way to connect the lower radiator hose is to remove the top of the thermostat housing cover, secure the hose to the radiator and then to the thermostat hosing and bolt it back together. Trust me on this one. Good luck GC
12-14-2008 | #6 |
I plan to do this replacement myself so I hope I don't run into problems.
I already have Samco hoses and I believe someone mentioned in the past removing the thermostat housing. The main thing I'm hoping is that I won't have to disconnect any airconditioning hoses. |
12-14-2008 | #7 |
Last year I installed a Ron Davis Rad. The drain is a alum plug. I called Ron Davis Rad and they said not to use Brass, SS or any metal drain valve other than Alum. which I can't find so I use the alum. drain plug. Your picture shows a brass drain valve, you might want to check on the use of Brass and alum.
Thanks, Jerry |
12-14-2008 | #8 | |
Then lift the left (driver's side) of the shroud first. The hang up will be on the right side, under the oil cooler and AC lines. It is hard to do the first time, but the shroud is very flexible. The right corner of the shroud will flex enough to get it out from under those lines. It takes some force, but it will come out. I did it this week and I got it out and back in. Once you have the shroud out, you may want to remove the fans. It is only three more screws and two wire connectors. It will make changing the hoses easier. Put the fans back in before the shroud. Good luck. PM me and I will give you my phone number if you need a friend to call. Jim
12-15-2008 | #9 |
The stand and shake the shroud method does not always work. Another way is to simply cut the corner of the shroud underneath next to the AC and oil cooler lines at a 45 Deg angle. Using a fresh pair of metal shears will cut the shroud like butter and will be almost unnoticable when the job is completed. I have heard the other method works and I agree the shroud is flexable but every car is different and the lines are not aways positioned exactly the same. IMHO this method puts a lot of stress on the AC lines and the oil cooler lines and can actually cause a strees crack to the shroud. This stated however it also CAN work. The cut the corner of the shroud method WILL work and reduces the stress on those lines. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-15-2008 at 08:50 AM. |
12-15-2008 | #10 |
GC,
I hear you. I wanted to trim that corner of the shroud sooooo much. If for no other reason than to take out some fustration. If it was a job I planned to do more than once in every 18 years, I would use your idea for sure. Jim
