Old 12-05-2008   #11
jonszr1
jonszr1's Avatar
Default Re: Quest for Stronger Rear Spindles
Originally Posted by FU2 View Post
Never installed them. No need too.The stockers are doing fine in the 441
IF I were to change over the rear to anything it would most likely be to a solid axle. The complete solid axle conversion can be had for @ 1300 and just about bolt right in.
where can this be had for 1300 ? would that be for a rewelded case only , the youput your own guts in it .?
Old 12-05-2008   #12
The 1300 is for the housing. The kit complete is 5K. The post has been edited.
I have to start paying more attention to my posting's
Still at 5K and no more worries about the rear end...... speed costs, how much money do we have ?
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 12-05-2008   #13
jonszr1
jonszr1's Avatar
i totally agree , thats allways the worry i have when i launch will she break . do you have info on where i could find the case conversion . it would save alot of time trying to figure this out on our own . id love to have this done before the season starts thanx for any help you can provide
Old 12-05-2008   #14
Here is a link to the CF :
http://forums.*************.com/c4-t...sion-kits.html
Ski is well known in the N/E area. The conversion is super strong.
Are you sure that you need it ?
Good Luck !
Corvette Nazi's won't let us post links. I'll pm it to you.
Frank Urbo.
Old 12-08-2008   #15
8upZR1
8upZR1's Avatar
Im kinda interested in the solid axle conversion too. Could you PM me with that link as well? Id really appreciate it.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!!
Old 12-08-2008   #16
Here you go :
http://forums.*************.com/c4-t...<br /> <br />
As you can see the Corvette Forum Nazi's don't allow linking. Go to the Corvette Forum and run a search in the C4 Tech/Performance section for solid rear axle conversion kits and it will link you right up.
Frank Urbo.
Old 12-08-2008   #17
Aurora40
Aurora40's Avatar
I believe it is this forum here that does not allow linking to CF. CF couldn't possibly technically prevent it, unless they legally prohibit it, which I doubt.
If you take that url and replace all the *'s with the url to corvette forum, it should work.
url
^--- That url should work in IE. In Firefox you may need to go to the address field and manually click the "enter" key.
Bob Saveland
Former owner of #2517
Last edited by Aurora40; 12-08-2008 at 07:06 PM. Reason: messing around with the url
Old 12-08-2008   #18
I tried it again and the *****'s appeared again. Odd.
Update : It's this site that screws up the linking. My bad.
Frank Urbo.
