Old 10-24-2008   #1
ZR1Vette
ZR1Vette's Avatar
Default Rotor plating...gearing up for the winter projects>>>
This winter's projects will be brakes and the plenum removal to replace injectors, coils and various pieces of plumbing. The brake rotors... wanted to go back to OEM rotors (I put on EBC sport rotors and while OK the look stands out too much for my tastes) but also wanted to kill the rotor rust issue. The plater I have been using (Specialized Plating in CA) got nailed by the CA EPA folks so I began looking. Found a very good company... better pricing, hell lot closer to me than CA and nice work . Georgia Plating and here are the OEM rotors back from them>>
Rear set
and the front set... cooling veins nicely finished
They also do zinc black and chromium plating and electro plating in various colors...
Old 10-24-2008   #2
Aurora40
Aurora40's Avatar
Default Re: Rotor plating...gearing up for the winter projects>>>
Looks nice! I'm guessing those are new rotors by the crosshatching on the friction surfaces? What are the two extra holes for?
Old 10-24-2008   #3
carter200
carter200's Avatar
Very nice looking
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-24-2008   #4
gbrtng
gbrtng's Avatar
What is the plating material?
Old 10-25-2008   #5
Wow...
Those look great!@!!
Another winter project could be Gordon Killebrew?
Old 10-25-2008   #6
ZR1Vette
ZR1Vette's Avatar
Yes... new rotors and extra holes??? No idea
The finish is zinc clear/bright finish...of course the finish on the rotor to pad contact area will be removed but rest of rotor will remain plated
And YES Gordon K...but looks like there will only be a few of us going at whatever date is established...look foward to it
