Hi Guys I am having troubles with high Idle and surging at idle. Ive checked for vacumn leaks and cant find any. Any Ideas????
cheers Ernie ![]() |
#2 | |
Have you done anything to the car recently? Did you powder coat the motor? |
#3 | |
TomC "Crabs"
Have powder coated the engine, while it was apart, because it had the same problem. Found a large vacumn pipe not connected under the phelnum, and when it went back together it was pretty good ,not perfect but a lot better. Seems to have gotten worse all of a sudden.
Have not had it on a tuner as they are hard to find out here.Only know of one guy that has the right gear. Have a haibeck chip in it, will that make any difference to the tuner.?? ![]() |
It sounds as if you still have a vacuum leak.
I'd check all your vacuum connections including the MAP sensor hose and the PCV system. It will make no difference to the tuner if you have a stock prom or a Haibeck prom. TomC "Crabs"
![]() ![]() Join Date: Dec 2004
Just tossing this out as a fwiw.....on my 90 it wasn't one or two big (detectable) vac leaks. Rather, it was a collection of really small ones from all the rubber parts in the PCV sys and the dual connector at the bottom left of the T-body....just a thought.
I used small zip ties to correct the T-body & two larger Z-ties at the PCV holder & it's top connector. I replaced both 90* el's @ the I/H's and made sure to re-tq the plenum bolts after a run cycle. I know that was a lot of redneck engineering but alot of that rubber is NLA from GM. Even the new stuff I bought when it was available didn't last long at being tight. I guess our underhood temps must kill the rubber parts quickly. ![]() Tom
Thanks guys, have tried most of those things, plus pcv's are new as is the double rubber thing they fit into. Have also clamped every bloody hose I can get at. Wil try the tune next and check again for leaks, ???
#8 | |
He did and fixed the issue! Problem is, I used a tech one to take the idle down and it did.... To where I had no idle! Had to trailer the car to a chevy station to raise the idle. That "could" be your issue, if the shop took apart your TB. Cheers ![]() |
Ern,
Persuiant to what Dave just posted......if when cleaning the T/Body the "dag" was removed and/or compromised that will affect the sealing of the blades in the body's bores' and allow for an air leak to the extent that the IAC can not compensate. "Dag" = blackish, rubbery substance forming a ring in the wall of the T/body bores to which the T/blades seat against. It allows for an air tight seal at 0% throttle. Now I was thinking that if your idle issue is only after the motor gets hot, reaches closed loop operation? Then there might be a sensor issue, as in a 'soft' failure. O2's, TPS. IAC, MAP, IAT; back probing for voltage may reveal something in the absence of a scanner. The Emissions & Drivability Section in the FSM has diagnostic charts for voltage values. Or there could be a fuel delivery problem if the idle issue is in open loop & closed loop; including the pressure regulator (look for gas in the reg vac hose), and gas filter & pump socks & primary pump & injectors. I would also check the ing system as an outside source. Okay, now the only other Q I have is the PROM. I'm not fluent in that stuff & I don't have a modified PROM from a tuner in my car. There was a TSB about the early 90 PROM concerning erratic hot idle issues.....only I Do Not Know if that is relavent here, sorry. ![]() http://www.zr1netregistry.com/bulletins/476503-1.jpg Sorry I don't have anything better to offer. ![]() Tom Just thought of this, and I'm not trying to be a wise guy.....did you check for oil in the MAP hose & in the nipple at the MAP? That can impair the MAP's signals to the ECM.
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 10-14-2008 at 10:32 AM. |
#10 |
Guys thanks for all the tech advice, but your talking to a builder here, not a mechanic, and whats worse is there are very few real mechanics out here that know anything about the LT5 motor. Its all a bit beyond me so Ill gather all this info and take it to the one bloke I know of that could help. The throttle body came off but was not powdercoated. I polished that myself , and I did know about the sealer inside. The problem only got worse recently, and I thought it may have been a poor batch of fuel, as it started to ping as well. Have a new lot of fuel now but havent had a chance to run it thru yet. Thanks again for the info, will let you know how I go.
