Old 10-06-2008   #1
Pete
Pete's Avatar
Default Head Gasket
Here we go again GM ran out of the RH Head gasket #10106176.
About a year ago they were out of the LH Head gasket and they produced a run of them cause of demand.
At the time i had figured out we could use the RH Head gasket on the Left bank.
What can/might help is, if everybody could run to there local dealer and order the RH Head gasget in hopes demand gets high enough for GM to run another batch of RH head gaskets.
I already have a dozen sets of head gaskets L & R and still have a couple of RH gaskets on order in hopes they reproduce some more but i don't think they will do it for just my 2 gaskets.
It costs about $25
Just a thought.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-06-2008   #2
bobbyhi
bobbyhi's Avatar
Default Re: Head Gasket
It costs about $25
Just a thought.
Pete
Doesn't A26B of this forum have the head gaskets? He seems as though he makes most of the gaskets for the LT5.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 10-06-2008   #3
tccrab
tccrab's Avatar
Jerry sells head gaskets, here's his latest price sheet:
http://www.zr1netregistry.com/forum/...ead.php?t=6754
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-06-2008   #4
Jeffvette
Pete, I don't believe GM produced more of those gaskets (or that their supplier did). I believe those gaskets were some that were found, as the packaging was definitely older as was the gm parts tag.
Jerry only has the stock GM gaskets.
Old 10-06-2008   #5
Pete
Pete's Avatar
Jeff, are you talking about the LH head gasket?
If so they look like newer packaging and they had the oil passage already cut out, so i thought they ran a new batch.
The stinker is we can use the RH Head Gasket on the left bank but not the other way.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
